Drivetrain Installed Milltek Catback - Service Engine Soon Light?
Old Aug 30, 2004 | 06:18 AM
Morefun's Avatar
Morefun
I installed the '04 Milltek cat back exhaust over the weekend. Nice product, easy install, not much louder than stock - as advertised. After about 50 miles the "Service Engine Soon" warning light came on. According to the manual "this indicates a malfunction in the emmissions-related electronic systems". Since the new exhaust is after the 02 sensor as well as the cat, what gives? Any insight would be appreciated.
Cheers,
Old Aug 30, 2004 | 06:28 AM
LilRedMini's Avatar
LilRedMini
Until you draw the exact code you are flying blind. It may very well be totally unrelated to the exhaust installation.
You need to find someone with a scanner or OBDII diagnostic software and determine the exact DTC.
Good luck,
Old Aug 30, 2004 | 06:39 AM
Jdewey's Avatar
Jdewey
service engine soon
I have never dropped my exhaust, but I recall a warning, that you should unpug the second O2 sensor before lowering the pipes or you will break the wires.
Old Aug 30, 2004 | 07:27 AM
Morefun's Avatar
Morefun
JDewey - the O2 sensor is forward of the cat back flange. It isn't disturbed when you drop the exhaust after the cat.....
Cheers,
Old Aug 30, 2004 | 09:15 AM
kenchan's Avatar
kenchan
Not sure if it'll help, but try re-torquing the clamp, then turn engine on/off 5 times to clear the CEL. if it turns on again, then its something else.
Old Aug 30, 2004 | 12:12 PM
Morefun's Avatar
Morefun
KenChan,
Thanks I'll give the on/off routine a try. I did re-torque the two flanges and single slip joint already. Too much silly electronic stuff!
Cheers,
Old Aug 30, 2004 | 02:42 PM
Morefun's Avatar
Morefun
kenchan
5X ON/OFF - That did the trick! Go figure..... na don't ask.
Old Aug 30, 2004 | 03:14 PM
DrkSlvrS's Avatar
DrkSlvrS
Morefun - I also installed the Milltek on my '02 ... the first few hundred miles the exhaust sounded about the same as stock but then it gets a little more aggressive (but only when you're putting your foot into it).
Have fun!
Old Aug 31, 2004 | 07:56 AM
LilRedMini's Avatar
LilRedMini
I'm not sure if your five hits of the switch clears the code or simply turns off the light. If it clears the code, you should not do it until you know what the code is.
I expect that it only turns off the light, but the code remains.
Good luck,
Old Aug 31, 2004 | 11:13 AM
kenchan's Avatar
kenchan
Originally Posted by Morefun
kenchan
Old Aug 31, 2004 | 11:28 AM
Morefun's Avatar
Morefun
LilRed
Good point. But as the dealer isn't down the street, I'll have to let it go for now. Thanks.
Cheers,
Old Aug 31, 2004 | 01:27 PM
LilRedMini's Avatar
LilRedMini
You don't need the dealer to draw the code. You probably have a neighbor or local independent shop that has a scanner or something. OBDII is a STANDARD that has been mandated in ALL cars sold in the US since 1996.
Because it is a standard, there are lots of people who can draw the code in any number of ways varying from cheap, handheld scanners to expensive equipment that is found at ALL brand dealerships.
Ask around.
Good luck,
09R56
Nov 16, 2022 10:49 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 12, 2015 01:24 PM
