Drivetrain Harmonic Damper install noise
Old May 1, 2015 | 06:39 PM
zip251's Avatar
zip251
I had my harmonic damper replaced ATI super damper and it makes rattle like Diesel engine at first start but goes away after initial drive ?? Was wondering if it was installed correct or is it inevitable or not torched correctly? Installer said its because metal to metal contact ..what else could it be ??
Old May 1, 2015 | 06:52 PM
bavmotors's Avatar
bavmotors
That doesn't sound right... Must be loose or something.
Old May 2, 2015 | 11:41 AM
Alan's Avatar
Alan
Agreed, something is not right!
ATI Superdamper on my R53 makes no noise.
Old May 2, 2015 | 08:25 PM
zip251's Avatar
zip251
Will this (noise) cause problems if left as is ..seriously thought of choking it with WW40...?...or would it be wise to have worked on again and replace value ring in process
Old May 2, 2015 | 09:09 PM
bavmotors's Avatar
bavmotors
well a noise usually indicates a problem, best to address it.
Old Jul 5, 2015 | 07:06 PM
zip251's Avatar
zip251
Another clue popped up it only makes noise when I turn the AC on ..!... So one would certainly conclude its the AC condenser but would it be wise to just change coil or replace unit ?!?
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 21, 2015 10:41 AM
