Drivetrain Zero Gravity Module
Old Jul 26, 2004 | 01:21 PM
iblair's Avatar
iblair
Zero Gravity Module
Bought this Zero Gravity Module on ebay, supposed to trick Intake Air Temperature sensor and give you 15 HP.
Anyone know about this?
Anyone know where IATsensor is?
Thanx
Old Jul 26, 2004 | 01:33 PM
Bisch's Avatar
Bisch
????link? anything???
Old Jul 26, 2004 | 01:34 PM
Bisch's Avatar
Bisch
without even seeing it, I'll be the first to say "snake oil!!!"
Old Jul 26, 2004 | 01:52 PM
Pankeyguy's Avatar
Pankeyguy
Oh come on!
You're giving "snake oil" a bad name.
Dave
Old Jul 26, 2004 | 02:08 PM
J-Didi's Avatar
J-Didi
I actually tried it (yeah I'm gullible, too). At first, I thought I noticed a difference,but after a while I wasn't so sure. I was concerned because it seemed to get HOT. I thought maybe engine heat was melting it or something.
Anyway, I took it back out and didn't notice any change in performance (which means it either never worked before, or it stopped working at some point before I took it out).
For those of you unfamiliar with the product it is supposed to "tell" your ECU that CAI is always 32 deg and therefore lshkdhghqegfheg????? :smile: .
Let us know If you have better luck. I'd really like to compare results.
Old Jul 26, 2004 | 06:54 PM
sonichris's Avatar
sonichris
i've seen similar devices, such as the power module for the KE-Jetronic system on my 86 16V scirocco (may god rest it's soul). it was basically a resistance module that would trick the jetronic computer into thinking the coolant temp was cold. this would dump extra fuel into the engine and make some power toward the higher rpms, and it did....BUT only on engines that benifitted from extra fuel, like my VW (schrick cams, adjustable cam gear, k&n, catback). with those mods my scirocco ran pretty lean, and the power module gave it a nice push. however, as most of you know, the mini runs rich on WOT programming. so.... dumping extra fuel would not be a good thing for the mini. considering all the aftermarket programming for the mini lean out the top end.... hmmmmmm...
my conclusion: snake oil
QED
Old Jul 26, 2004 | 07:04 PM
sonichris's Avatar
sonichris
just read the original post again...
it seems that i missed that this module works on the intake air temp, NOT the coolant temp. this changes things a bit.... i know that the mini ecu will dump extra fuel to cool the intake charge when the IAT is high. this module would prevent that. but here's the question:
is there more or less fuel for hotter air?
considering that cooler air is more dense (more air molecules), i would think that this would call for more fuel. hot air is less dense, thus less fuel, does this make sense? if this is the case, it is still making the mixture richer, which isn't good. but.... i'm guessing now. ...and blabbing on about things i don't know... yes, it's best to just stop now.
Old Jul 27, 2004 | 06:54 AM
Pebblecrusher's Avatar
Pebblecrusher
I'm still waiting for a Flux Capacitor to show up on EBay for our MINIs.
Old Jul 27, 2004 | 07:18 AM
iblair's Avatar
iblair
What is a flux capacitor?
Old Jul 27, 2004 | 07:30 AM
biggripper's Avatar
biggripper
FOUR words.
BACK TO THE FUTURE
Old Jul 27, 2004 | 10:29 AM
J-Didi's Avatar
J-Didi
Stop man, you're killing me.
Old Jul 27, 2004 | 10:42 AM
Bisch's Avatar
Bisch
It only works at like 86 mph though!
Old Jul 27, 2004 | 11:00 AM
Audioman's Avatar
Audioman
The MINIs electrical system would have to be substantially upgraded to handle the 1.21 Jigawatts!!!
Old Jul 27, 2004 | 01:49 PM
kumquat78's Avatar
kumquat78
HOW DARE YOU MISQUOTE BACK TO THE FUTURE!!!
I believe that's 88 MPH
Close though!
Old Jul 27, 2004 | 02:27 PM
greatgro's Avatar
greatgro
88 is correct!
Old Jul 27, 2004 | 02:31 PM
Bisch's Avatar
Bisch
Originally Posted by greatgro
88 is correct!
Yeah! If you are reading the MINI speedo, that is correct! Your actual speed, however, would be 86mph!!!!
I knew someone would catch me on that....
Old Jul 27, 2004 | 03:16 PM
greatgro's Avatar
greatgro
Tell that to the cops!
gar56
Nov 15, 2016 06:41 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
GAT
Oct 4, 2015 07:27 PM
Suspension Products
Oct 1, 2015 11:53 AM
Sep 25, 2015 12:32 PM
