Drivetrain Jb+ vs maniv stage 1
Old Jan 13, 2015 | 04:43 PM
larmini's Avatar
larmini
Ow would u guys rate them to each other. Etc sorry manic bms jb+
Old Jan 13, 2015 | 05:58 PM
minivinnie92's Avatar
minivinnie92
This has been asked a few times check out the other threads on this also check out the manic thread
Old Jan 14, 2015 | 04:11 AM
larmini's Avatar
larmini
Just wondering if it's worth it to get the jb+.
Or go with the manic tune.
Old Jan 14, 2015 | 04:34 AM
minivinnie92
If you read the manic thread u will see even the stage one Map A is a world's difference contact mariokart he will explain there is an entire thread on this as well
Old Jan 14, 2015 | 04:43 AM
cerenkov's Avatar
cerenkov
Depends on what your looking for.
The JB+ is user installed in minutes, warranty friendly and adds about 10-15 HP. Costs $200-$250 on the used market.
The Manic tune is flashed at a Manic dealer or you have to mail the ECU in. It would surely void your warranty but it adds more HP depending on your supporting mods.
I've had both and the Manic tune wins hands down from a performance standpoint. It produces more boost, more timing and better AFR.
But it's comparing apples to oranges. It's not really fair to compare the JB+ to a ECU tune they serve two different purposes.
Old Jan 14, 2015 | 05:01 AM
larmini's Avatar
larmini
Will you notice a difference with the JB
Old Jan 14, 2015 | 05:20 AM
cerenkov's Avatar
cerenkov
Yes, I did notice a difference.
Old Jan 14, 2015 | 08:11 AM
MiniSkoon's Avatar
MiniSkoon
I have the JB+ so I can only speak to that but yes, it works and IMO is pretty nice for $300 (new.) I'm still under warranty for another year and my MCS is stock so a tune doesn't make sense for me right now. If you're brave, you can play with the dial on the JB+, to further increase boost. I currently have it set at around 75-80% using a 75/25 mix of 93octane/ethanol, giving me around 96 octane and the JB is even more noticable. But if you are out of warranty or don't care and have the supporting mods, i'd get a tune. You'll gain atleast twice the power the JB will give you and it will be tweaked more for better driveability. good luck
Old Jan 14, 2015 | 08:24 AM
larmini's Avatar
larmini
No I'm still way under warranty. .I just want a better ride.
Old Jan 14, 2015 | 08:43 AM
MiniSkoon's Avatar
MiniSkoon
A tune will 100% void your warranty. The JB+ you can simply unplug before you take the car in for service and will not be detectable. Plug it back in when you get home. An older post by Terry at BMS (from what I remember) showed he ran a 14.2sec. 1/4 mi. @ 104mph with 94 octane and the JB set at 75% on what I think was a stock MCS, so it works. I believe the info he shares.
Old Jan 14, 2015 | 09:18 AM
larmini's Avatar
larmini
Yes I don't want to screw with warranty.
But definitely want more power
Old Jan 14, 2015 | 09:39 AM
MiniSkoon's Avatar
MiniSkoon
Just do it! I don't really consider it a mod but I also use a k&n drop-in filter. Add's to the fun with a little more turbo noise. So between those two, for $340 and you will have about the same power to weight ratio as a new stock VW GTI, if you're looking for further power comparison.
Old Jan 14, 2015 | 10:07 AM
u238's Avatar
u238
The JB+ is VERY noticeable. It's a great deal, especially because it installs and removes in 30 seconds. Pick one up in the for sale forum here. Lots of people seem to be selling them since the n18 DME was cracked.
Old Jan 14, 2015 | 10:26 AM
Ovrclck's Avatar
Ovrclck
I'm only at only 16k miles and my warranty expires @ 75k miles. Hmm, I don't think it's wise to void my warranty just yet. lol
Old Jan 14, 2015 | 10:30 AM
MarioKart's Avatar
MarioKart
Vendor
The Manic is near impossible for the dealer to read and one of the great things about the Manic Tune is you can switch it to 100% ECU setting in 5 seconds. I have tons of customers with Manic that go to the Dealer for service and warranty work. The only thing the dealer can do it write over the Manic tune with a new ECU version, but that rarely happens and the N18 is pretty much done with new ECU updates
mQubed Motorsport, Manic Tuning Dealer
Old Jan 14, 2015 | 10:36 AM
minivinnie92
Mario is right plus I've heard that the jb can b hit or miss I have mine turned up to 70 and only gained 1 psi and not much power I also have catless dp and intake
Old Jan 14, 2015 | 10:41 AM
Ovrclck's Avatar
Ovrclck
This is great news then!! I can see a Manic tune soon.
Old Jan 14, 2015 | 11:09 AM
MiniSkoon's Avatar
MiniSkoon
Doesn't this tune or any other ECU tune need to have supporting mods (ie. aftermarket FMIC) to be able to handle the extra power/heat to prevent damage? If so, wouldn't those additional mods potentially void the warranty even if the ECU tune went unnoticed?
Old Jan 14, 2015 | 11:13 AM
MiniSkoon's Avatar
MiniSkoon
I'm no expert and I'm not always monitoring boost but just by feel, I've never felt at any moment anything even close to stock conditions with the JB+ plugged in and adapted. Boost can increase/decrease with the change of weather/location.
Old Jan 14, 2015 | 11:55 AM
larmini's Avatar
larmini
I just want some better power for now.the tune is more expensive and then u need the tool to turn it on off etc. Hopefully the jb will be noticeable difference
Old Jan 14, 2015 | 12:39 PM
cerenkov's Avatar
cerenkov
Why would you ever turn it off????
Old Jan 14, 2015 | 12:48 PM
larmini's Avatar
larmini
Turn off the tune b4 u bring it to dealer for service.
Old Jan 14, 2015 | 12:59 PM
cerenkov's Avatar
cerenkov
Why? When you take it in for maintenance they change the oil, they don't drive around recording boost levels, doing 0-60 runs, etc. They might notice that it's peppier than other cars but they drive different cars all day long and they probably don't care enough to notice.
In the end do what you're comfortable with.
Old Jan 14, 2015 | 01:07 PM
larmini's Avatar
larmini
No they notice.them when u have a problem they will bring it up.
Old Jan 14, 2015 | 01:26 PM
Mini Union's Avatar
Mini Union
I have my JB+ on my 2013 and I never ran into a problem at the dealer.
