Drivetrain Bytetronik questions
Old Dec 15, 2014 | 10:02 PM
Kr4nG's Avatar
Kr4nG
Ive been reading about the bytetronik tuning tool for the past few hours and i wanted to clarify some things. They claim its a one vehicle tool. Meaning once purchased and installed to the ecu it is married to that car. Well they say that you can uninstall it from the ecu which takes 5 min to return the ecu back to stock. Once uninstalled can the user reinstall it back to the same ecu? I assume yes. But can you reinstall to a different ecu.
Also if you reset the adaptations on a tuned ecu will the tune be erased or reverted back to stock? Im assuming no the adaptations are different from the tune.
Any feedback on there experience with this tool? Good or bad? Or is there anything better that is out there now.
Old Dec 16, 2014 | 05:37 AM
Saltysalt's Avatar
Saltysalt
it is a one vehicle tool, meaning once you plug it in into your obd2, it reads your vin and stores it. bytetronik them selves can reset that, you cannot. it can be used for life on that 1 vin number. its a tool that can write to your ecu. once its plugged in, it copies the stock file, which you then can load on your computer, or somewhere, even the SD card than can fit in the unit. and then it loads in another file. which it either made by you, or mynes tuning.
reseting the adaptations are for that tune only. think of your getting rid of windows 7, loading in Linux, and when you no longer want Linux, you can load windows 7 back in
hope this helped, I haven't personally used mine yet, still waiting on time mostly to work on my car
Old Dec 16, 2014 | 09:36 AM
Kr4nG's Avatar
Kr4nG
Thank you for the reply but I have some more questions.
1. If I custom tune my ecu can the dealer flash over the ecu and reset my tune by putting in their factory tune? Will they get an error saying FA is installed?
2. So if I custom tune my ecu and keep resetting the adaptations my custom tune will still be installed correct?
3. The bytetronik tool does not use live tuning parameters correct? This means you have to data log it first to see what occurs. Then go back in and change your maps and upload. Then data log again to see what occurs second time and on.
4. If a pro tuner wants to become part of the mini tuning community how can they use the bytetronik for multiple vehicles (because they are a business) if only one tool per vehicle is allowed.
Old Dec 16, 2014 | 09:50 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The dealer can only flash over your tune and set it back to stock, but at this point your car is out of warranty so just tell them when you go in NOT to flash your ECU.
Resetting adaptations will NOT effect the tune. The only reason to reset adaptations is if you do a repair. Otherwise you should not be resting the adaptations.
Yes there are NO live tuning, you have to log then adjust.
If a tuner wanted to use it they would have to get a copy for each car as that is how bytetronik makes their money. Otherwise everyone would by one copy and share it
Old Dec 16, 2014 | 10:28 AM
Saltysalt's Avatar
Saltysalt
and if the dealer flashed it back to stock, mynes has all your files anyways, or youll still have it in an email. they can tune live, but you need dyno access with them
Old Dec 16, 2014 | 11:07 AM
Bytetronik's Avatar
Bytetronik
Below are some answers to your questions:
1. If FA is loaded on the ECU, the dealer will NOT be able to write over it. They will get a communication error "unable to communicate with DME/ECU".
2. Adaptation only kicks in to compensate if your current 'tune' is not running correct. If the tune is dialed in, then there is no need to reset adaptations.
3. Correct, no live tuning.
4. We have Dealer discounts available; interested parties should contact us directly.
BT
Old Dec 16, 2014 | 11:50 AM
Kr4nG's Avatar
Kr4nG
Thank you for all the clarification. I come from the honda scene so the ecu tuning is another world compaired to what needs to be done before they can get into it. My car should never see the dealer anyway cause i do all the work myself. In the future I might consider this tool because it seams the most affordable and fastest way to tune my r53 without buying a standalone ecu. (specs of car in my sig)
Hey bytetronik if i tune my car using your tool will my 2096 code disappear? Well not disappear but sort of straighten the lean code im getting at a certain point. No matter what i do i cant get rid of this code. And only code that I have. Its a lean mixture code that occurs every 320 miles after i reset my adaptations. (factory spec ecu) I still might have an exhaust leak but if i do its deff past my second o2 sensor. Code started happening after i put my header and race cat. To bad i dont have my factory header anymore.
Old Dec 17, 2014 | 05:09 AM
Saltysalt's Avatar
Saltysalt
could have a vaccum leak in the motor to help cause the lean code
Old Dec 17, 2014 | 10:02 PM
Bytetronik's Avatar
Bytetronik
It is never a good idea to use Software (tune) to try to solve a hardware problem. The purpose of a tune is to optimize the hardware components, but if the hardware is faulty, then the tune will never never be "perfect"... And this is when the ECU will try to adapt in an attempt to make it run 'right'.
Also check your vacuum line that connects the bottom of the FPR to the underside of the inlet horn... on oem setup, that line can pop out quite easily.
Old Dec 21, 2014 | 06:35 AM
Kr4nG's Avatar
Kr4nG
Thank you for the suggestions that line is t-ed off into my aem electric boost gauge and i doubt that could be leaking. (I used wire to tighten the hoses) Does the FA program have features to disable codes like the ecu flash does? (Patch fixes) If FA is installed and running on the ecu 100% no codes can the inspection station pass their tests and let you pass inspection or will they get an error. (Im hoping you will pass obd2 tests)
Thank you
Old Dec 21, 2014 | 01:04 PM
Bytetronik's Avatar
Bytetronik
Thank you
There are many many FA-installed R53s running around and passing smog inspections
The stock ECU will respond to OBD commands (it just won't allow the FA-loaded ECUs to be flashed over by another tool).
Yes, certain patch fixes are available (more detailed info can be found on the Tech Forum for current FA owners).
Old Dec 21, 2014 | 07:25 PM
Kr4nG's Avatar
Kr4nG
I really want to thank you for your time answering my questions. I am now confident on purchasing this tool for my needs. Cant wait.
Old Dec 21, 2014 | 09:10 PM
Kr4nG's Avatar
Kr4nG
to my understanding the tech forum is not available to public until i purchase the product? what if i just want to read peoples comments and learn more about it by reading your forum.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
