Drivetrain Headers
Old Oct 23, 2014 | 05:40 PM
Tuningcars's Avatar
Tuningcars
Headers
So I just bought Megan Racing headers for my MCS and yes it is the one that deletes the catalytic converter. I probably should have asked this before I bought them but will it make a tin can noise? Or will it make it more bassy? I have a Borla Race exhaust on the car and would love to enhance the already deep sound.
- Thanks!!
Old Oct 23, 2014 | 10:42 PM
Hawthunk710's Avatar
Hawthunk710
I have had them installed for about 2 weeks. Resonator is pretty much melted out and it sounds F&@KING awesome!! It has a little backfire and actually you can feel the bottom end power.
Old Oct 24, 2014 | 01:56 PM
Tuningcars's Avatar
Tuningcars
Great to hear, I was alittle nervous about them but am glad to hear that. I am getting the car tuned in a couple weeks so hopefully itll give it even more power
Thank you for the info!
Old Oct 31, 2014 | 07:32 AM
TheBigChill's Avatar
TheBigChill
Putting a stainless header and catless exhaust on a 1.6L SOHC supercharged motor will never be 'bassy'. It will be loud, but never bassy. The change in header material, primary tube length, and absence of a cat will make the exhaust raspy compared to it's previous sound.
Old Oct 31, 2014 | 04:39 PM
jsquaredkim's Avatar
jsquaredkim
yeah mine isn't bassy, but it is loud but only during WOT. It sounds like Honda B20 motor on crack.
Old Nov 5, 2014 | 10:45 AM
TheBigChill
Same here.
Old Dec 3, 2014 | 07:11 AM
Tuningcars's Avatar
Tuningcars
Yea I have had them installed for a little over 2 weeks now, I'm happy with them, they unleash the cars inner beast WOT But I have a small fitment issue, where the deleted cat and cat-back meet, did any of you have a hard time connecting them? There is a small gap and the gasket rattles just a little... any suggestions?
-Thank you all!
Old Dec 3, 2014 | 11:13 PM
Hawthunk710
Originally Posted by Tuningcars
Yea I have had them installed for a little over 2 weeks now, I'm happy with them, they unleash the cars inner beast WOT But I have a small fitment issue, where the deleted cat and cat-back meet, did any of you have a hard time connecting them? There is a small gap and the gasket rattles just a little... any suggestions? -Thank you all!
i had that as well. I had to completely adjust my exhaust and I got it to squeeze together. I put new bolts in the place of the old rusty ones and used a couple of washers. Fixed the problem. Hope you can get it to work.
Old Dec 4, 2014 | 04:55 PM
Tuningcars's Avatar
Tuningcars
Ok, thank you so much!
Old Jan 17, 2015 | 02:35 PM
mellenberger65's Avatar
mellenberger65
Can you all more details on how you got the header to mate up with the rest of the exhaust? I already had the Borla S-Type with resonator installed and I am trying to add the Megan Racing Header with the test pipe. Problem is it looks like the down pipe is about 2 inches too short because to have any chance of the two mating, the resonator would have top be pushed about that far through the floor pan.
I guess if I deleted the resonator and added a straight pipe I could get it too work but I really don't want to do that. I have even chopped up the original manifold and a Magna Flow header trying to piece and part something together but I do not like how it is turning out.
I sent a video to Megan Racing on Friday showing them the problem but I bet they will come back with an "it would fit a factory cat-back just fine" type of response.
Any help/advice would be greatly appreciated.
Old Jan 18, 2015 | 09:00 AM
Tuningcars's Avatar
Tuningcars
I have the Borla Race exhaust so I don't know if the resonator is different, but what I did was use a jack to push the resonator up to just fit on the header ( it is a very tight fit and has no flexibility at all ) Then I allowed the car to run, and rev it a lot to get the header and resonator very hot and carefully adjusted and tightened the whole piece together, I have not had any problems yet.
It is kind of disappointing however, you would think a Megan Racing piece would be more reliable. I hope this helps
Old Jan 18, 2015 | 02:45 PM
mellenberger65
Not sure of the difference either. Mine is about 6 inches in diameter. Is yours closer to being a strait pipe?
Old Jan 25, 2015 | 01:51 PM
mellenberger65
I talked to Megan and they simply said to send back the header for a refund. They didnt seem interested at all in trying to figure out what was wrong woth the build and come up with a fix. If it werent that right now it is hard to find a header for my Mini that isnt going to cost me $800 - $1600 I would have sent it back but instead I ended up taking the cat off of the broken MagnoFlow exhaust and then I welded a cuople of very odd angled flanges on it and got it too fit. It aont the prettyest thing but it got me going for $200 rather than $800.
Old Jan 26, 2015 | 09:53 AM
TheBigChill
OBX unit is inexpensive and performs fairly well.
Old Jan 26, 2015 | 10:09 AM
mellenberger65
Yea... that was actually my first choice but I could not find them in stock anywhere. Best I could find was that they would be available sometime in March. Actually found the same with the Megan header but ended up finding a new one on eBay.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:13 PM
PhoR53
Sep 30, 2015 06:54 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:11 PM
