Drivetrain EBay intercooler [FACTS]
Old Nov 6, 2014 | 03:33 PM
  #26
bratling's Avatar
bratling
Super Moderator
Originally Posted by ridinDirty
Good link. That guy's writing is horrible beyond words, but there's a lot of useful info there if you can make it past the mangled syntax!
Particularly relevant to our thread here is this section:
http://www.are.com.au/techtalk/intec...20Intercoolers
Old Nov 6, 2014 | 05:38 PM
  #27
ridinDirty's Avatar
ridinDirty
yes, there is some great info in there. He even speaks well about a few of the overseas coolers....
Dam I didn't know I was going to be graded on grammar on this website.....lolol
I'm doomed
Old Nov 8, 2014 | 03:29 AM
  #28
jomama12's Avatar
jomama12
would this fit an R-58 and Is it necessary to get one with the centre bracket?
Old Jan 2, 2015 | 12:31 PM
  #29
UncDeo's Avatar
UncDeo
is there an ebay intercooler that fits really well on a 2011 MCS...with no cutting?
Old Jan 3, 2015 | 09:50 AM
  #30
CHKMINI's Avatar
CHKMINI
Spend the money and buy the best Intercooler for your Coupe....the Helix Step Core.
Old May 19, 2015 | 08:19 PM
  #31
rckrzy1's Avatar
rckrzy1
Ok got my eBay FMIC today. First, out of the box in perfect condition , no bent anything, including tabs, double boxed too. Got from same seller OP used.
Initial notes, weighs slightly more than forge , my scale said 14.5 pounds. Not enough to notice, eBay has 14 rows vs forge 11 rows, not sure on how this will effect because you have to calculate vol etc of each.
I like the clean look of cast end caps. Then I pressure tested it to 40 psi , no leaks. Will be installing this weekend. And let you know how install goes.
Friday night I'll be having to pull my splitter first.
Old May 23, 2015 | 02:53 PM
  #32
rckrzy1's Avatar
rckrzy1
Ok, installed mine, fit with no issues, clears the "new" bumper bar on my 2013. I did have to remove entire steel bumper assy to install, but thats a piece of cake to remove compared to getting to that point. Tapped a 1/4 20 hole for center tab, which some say it don't work ? I dunno maybe different year. and the KICKER it WORKS GREAT, did some full long pulls to 90 mph and and ambient was 83 , max IAT was 88 , held it to 5 degrees, that is 10 times better than stock.
Old May 23, 2015 | 04:27 PM
  #33
Noodle_10's Avatar
Noodle_10
I just wanted to add to this.
I got mine ebay FMIC yesterday and did the install today. Fit and clearance were fantastic, just as rckrzy1 claims. The top tab may not really be necessary, but I'm glad I picked up one with it just for that added piece of mind. I ended up drilling a small hole in the back of the bumper and a large one in the front so I could use a nut instead of a tapped hole. I do have a tap and die set but it must have eloped with my 2nd jack stand, neither can be found at this time.
The only complaint I really have about the whole process isn't the FMIC, it's those damned push-button fasteners, especially the ones holding the inner fender well in place. Those were very uncooperative. Oh, and the torx screw behind the side-marker lights. Had to really pull on the fender trim to line up the screw with the torx driver.
Overall I'm very happy with the results. Feels like step one has been completed in what should turn out to be a lot of future mods. Unfortunately, it will probably be awhile before any more happen.
Old May 24, 2015 | 07:54 AM
  #34
rckrzy1's Avatar
rckrzy1
But with $$$ saved buying the ebay FMIC I saved enough for a manic tune
Old May 24, 2015 | 05:58 PM
  #35
minivinnie92's Avatar
minivinnie92
O your gonna love manic also did you guys purchase from same eBay store as op?
Old May 24, 2015 | 06:31 PM
  #36
rckrzy1's Avatar
rckrzy1
D51msport ,so I think so. Again it was double boxed and arrived perfect .
Old May 24, 2015 | 06:44 PM
  #37
minivinnie92
awesome can't wait to order one up
Old May 25, 2015 | 04:52 AM
  #38
Noodle_10's Avatar
Noodle_10
Not the same vendor; zpcsports here. Pretty sure it's sourced from the same supplier though. I just chose a vendor with good rep and a pic with the top tab. Other vendors are showing without the top tab so I wasn't sure if they were the same.
Old May 25, 2015 | 09:09 AM
  #39
minivinnie92
I doubt it really needs the top tab but hell y not
Old May 26, 2015 | 05:40 AM
  #40
Noodle_10's Avatar
Noodle_10
Exactly.
Old May 27, 2015 | 09:19 AM
  #41
rckrzy1's Avatar
rckrzy1
BTW , I changed my signature to reflect I run a FORGEry FMIC LOL
Old May 27, 2015 | 10:18 AM
  #42
Baconism's Avatar
Baconism
so what else would you replace/upgrade while doing intercooler?
Old May 27, 2015 | 10:41 AM
  #43
rckrzy1's Avatar
rckrzy1
yes the one I bought fit the 2013 even with the extra crash bar, would fit easier as you would not have to remove bumper assy.
Old May 27, 2015 | 10:43 AM
  #44
rckrzy1's Avatar
rckrzy1
nothing else that I can think of, I did the hot side muffler delete but no reason to do it at that time, in hind sight it was the most difficult and useless mod so far.
Old May 27, 2015 | 10:49 AM
  #45
Baconism's Avatar
Baconism
I already did that delete as well $8.00 at autozone
Old May 27, 2015 | 11:12 AM
  #46
minivinnie92
same here i spent 7.99 biggest pain in but to get the bolt that holds the muffler out and did absolutely nothing for me
Old May 27, 2015 | 09:11 PM
  #47
Baconism's Avatar
Baconism
Does the R56 and R55 have same intercooler? I see that in some headers but item description only says R56.
Old May 28, 2015 | 05:15 AM
  #48
rckrzy1's Avatar
rckrzy1
[QUOTE=Baconism;4086292]Does the R56 and R55 have same intercooler? I see that in some headers but item description only says R56.[/QUOTE
Yes, all the same undersized ic
Old May 28, 2015 | 05:09 PM
  #49
sub3622's Avatar
sub3622
rckrzy1, can you post the link where you bought the ebay ic.
I'm trying to find it on ebay but it seems that is no longer for sale
Old May 28, 2015 | 05:14 PM
  #50
rckrzy1's Avatar
rckrzy1
Seller is D51MSPORT
Item 281375378798
