Drivetrain engine mount (bottom one)
Old Sep 4, 2014 | 01:23 PM
kadaj's Avatar
kadaj
Nm sells one, I have always read that is a nice upgrade and improves drivability, may I know why? What does it exactly do? And why does it help?
Thank you!
Old Sep 5, 2014 | 06:11 AM
Club77's Avatar
Club77
Isit the same as Powerflex? Is there any noise, vibration?
Old Sep 5, 2014 | 07:18 AM
kadaj's Avatar
kadaj
Maybe a Lil vibration, and a Lil noise on the right side, but I think that has to do w a bad link or bushing
Old Sep 5, 2014 | 10:13 AM
PrplPplEtr's Avatar
PrplPplEtr
Vibratechnics. Do it right, don't bolster crappy OEM with inserts.
Sent from my Moto X using NAMotoring
Old Sep 6, 2014 | 12:55 AM
barnoun's Avatar
barnoun
Definitely Vibratechnics. I've had a BSH lower mount and Powerflex inserts (similar to NM), they don't compare at all to the Vibratechnics.
Old Sep 6, 2014 | 09:22 AM
johntotah94's Avatar
johntotah94
The problem with the BSH is too much vibration in the cabin. Inserts were fine but not aggressive enough. Curious how the Vibratechnics is.
Old Sep 6, 2014 | 12:59 PM
barnoun's Avatar
barnoun
The car has the same connectedness as the BSH but without the horrible in cabin vibration.
You can tell its not stock but its not harsh at all.
Old Sep 6, 2014 | 03:10 PM
danjreed's Avatar
danjreed
Thank you!
I have the NM one,
What it does is prevent the engine from moving excessively in the engine bay. When you drive the car, and accelerate, the engine moves in the mounts before it transfers power to the wheels. By adding a stiffener (mount) you limit the range of motion and get a quicker response from the drivetrain.
the NM mount goes around the factory mount rather than replace it. It only really "helps" under engine load (acceleration) rather than just being a stiff chunk of plastic that sends engine vibrations into the car.
While its not as "strong" as other mounts mentioned here, its perfect for the person who just wants a little more performance, positive drivetrain engagement, and a mod that literally takes about 3 min to install.
As a owner of a stick car, I say its a must. It eliminates the "rubber banding" of the engine swinging back and forth.
Old Sep 6, 2014 | 03:54 PM
jkapinos's Avatar
jkapinos
Ordered the Vibratechnics and will replace the NM I've had since the car was new.
Old Sep 7, 2014 | 09:52 AM
R53Warrior's Avatar
R53Warrior
Let us know what you thoughts are on it. I'm a little skeptical on the vibrations from the vibratechnics. The bushings look really small
Old Sep 7, 2014 | 10:02 AM
R53Warrior's Avatar
R53Warrior
I just looked at the photo of it again and its hard to judge the size without any reference. Where are you guys buying these from. The drive train lash is driving me nuts. I had all the mounts inserted/replaced on my R53
Old Sep 7, 2014 | 08:33 PM
barnoun's Avatar
barnoun
https://www.greeneperformance.com/mini.html
Old Sep 12, 2014 | 03:00 PM
jkapinos's Avatar
jkapinos
Received mine today. Looks very well made. Will install in the morning.
Old Sep 12, 2014 | 03:09 PM
R53Warrior's Avatar
R53Warrior
Great Looking forward to hearing your impression.
Old Sep 12, 2014 | 04:25 PM
mbwicz's Avatar
mbwicz
FWIW, A few years ago I bought the powerflex yellow ones. I ran for about 1500 miles, but removed them because of vibration. My car is an auto, and the vibration was very significant, especially at a stop light with the A/C on. I then installed the NM inserts, and have found them to be acceptable from a vibration standpoint. The reduction of torque steer is welcome, and I'm happy with this setup.
Have fun,
Mike
Old Sep 12, 2014 | 05:06 PM
user 7082082's Avatar
user 7082082
I am selling both r53 and r56 mounts in the FS section on this forum.
Old Sep 12, 2014 | 05:07 PM
jkapinos's Avatar
jkapinos
I've had the NM since I got the car in late 2012. Will try this one and let you know. By looking at the quality, I'm thinking I'll like it.
Old Oct 21, 2014 | 06:37 PM
troyegly's Avatar
troyegly
How is the mount working / impressions?
Old Oct 22, 2014 | 11:32 AM
Porthos's Avatar
Porthos
I have the NM inserts that I have had the car for around 80k miles. I think they are wore out because I am getting a lot of movement in the engine. I am looking at the bsh, the torque solutions, and the vibratechnics mounts. I am not worried about vibration because the coilovers make the ride rough as it is.
Old Oct 23, 2014 | 07:31 PM
barnoun's Avatar
barnoun
Get the vibra-technics. The torque solutions appears to be the same as the bsh. I've had the bsh and it makes the car feel like it's about to fall apart. I had it for more than a year then gave up and took it off. I tried the power flex black as well but they didn't feel that good. Too much vibration and not a very connected feeling.
The vibra-technics vibrates when you first install, then it starts settling down. I've had mine a couple months now and I love it, wouldn't trade it for anything. It feels as connected as the bsh but way smoother.
Old Oct 23, 2014 | 08:28 PM
Porthos's Avatar
Porthos
I am not really too worried about the vibrations. Plus I am on coilovers so everything shakes. I just can't see why this is $60 more the Torque solutions and BSH.
Old Oct 23, 2014 | 08:51 PM
scubbysnacks's Avatar
scubbysnacks
Also have an auto with an NM insert and was thinking about removing it then decided to pull it spray a liberal dose of silicon lubricant and reinsert reduced vibration at stop lights by about 40% much better!
Any suitable lub that doesn't attack the rubber/ polyurethane should have a similar impact on vibration.
Old Oct 23, 2014 | 11:49 PM
barnoun's Avatar
barnoun
Go ahead and get the BSH, unless you only track the car, you'll regret it.
Old Oct 24, 2014 | 05:16 PM
Porthos's Avatar
Porthos
Yeah that is why I don't advice on here. Just because you say so doesn't make it a bad product. I need more then "I told you so" to make a decision.
Old Oct 24, 2014 | 06:11 PM
barnoun's Avatar
barnoun
Go for it man.
