Drivetrain Boost gauge Help!
Old Jun 18, 2004 | 05:00 AM
felix's Avatar
felix
Boost gauge Help!
I want to install a boost gauge but have a few problems...
First I have NAV, so most of the ones that are designed for the Mini are for non-nav Mini's.
Second, those models are too costly.
Is there not a cheaper way to add a boost gauge than 300-500 bucks? What is involved? How is the gauge connected to the car's electrical and vaccum?
Any ideas would be a help, thanks,
James
Old Jun 18, 2004 | 05:11 AM
BluMiniMe's Avatar
BluMiniMe
Try looking at "mechanical" boost guages. Typically they run $45-$65 bucks. In addition to a couple of lighting wires, they only require a small plastic tube to be routed from the engine bay to the guage. Some "mechanical" boost guages also require a small kit to fit them ($10 worth of tubing, clips and wire splices).
As for mounting the guage, all manufactures have a variety of pods available at very reasonable prices ($15). They are usually black plasic swivel housings that can be stuck or screwed to any location/surface you choose.
Wish someone made an A-pillar mounting pod that would work with the MINI.
Old Jun 18, 2004 | 06:31 AM
Helix13mini's Avatar
Helix13mini
Felix:
We have the single mechanical gauge kit (gauge, hardware, etc.), cup, and bracket for $199. The bracket is designed specifically for cars with nav., and can mount 1, 2, or 3 gauges.
Eric
Old Jun 18, 2004 | 07:51 AM
felix's Avatar
felix
Dam
Eric,
I was there tuesday when you installed my 19% pulley, I wish I knew I would ahve picked it up then.. Shoot me an email at jfelix@sankyopharma.com to let me know how much to install it also. May be you can do a rear swaybar and the gauge install.
Thanks,
James
Doc Pain
Oct 28, 2015 07:09 PM
Oct 1, 2015 12:13 PM
papawhiskey
Sep 30, 2015 02:50 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
