Drivetrain CHEAP SC Air Diverter.
Old Apr 28, 2014 | 12:46 PM
BoogieBear's Avatar
BoogieBear
After seeing the outrageous prices of bolt on air diverters, I decided to see if I could make one. Sure enough I did. 2.5' of aluminum J bead/ sheet rock edger, tin snips and black paint.
Old Apr 28, 2014 | 12:56 PM
BoogieBear's Avatar
BoogieBear
I have no sheet metal experience. But I'm sure someone can manufacturer this for less than $20.00 out of stainless steel.
Attached Thumbnails CHEAP SC Air Diverter.-1398714591800.jpg   CHEAP SC Air Diverter.-1398714654463.jpg   CHEAP SC Air Diverter.-1398714696744.jpg
Old Apr 28, 2014 | 12:58 PM
bavmotors's Avatar
bavmotors
I'll take one in red please.
Old Apr 28, 2014 | 01:05 PM
BoogieBear's Avatar
BoogieBear
This is what i used. Because the edges are rolled so it gives it more strength.
Old Apr 28, 2014 | 05:23 PM
MINI VINI's Avatar
MINI VINI
I like the design, its more of a supplement to the stock diverter
Old Apr 28, 2014 | 05:28 PM
BoogieBear's Avatar
BoogieBear
Originally Posted by MINI VINI
I like the design, oh how its more of a supplement to the stock diverter
it forces all the air that comes in through the scoop, through the IC
Old Apr 28, 2014 | 05:41 PM
ZippyNH's Avatar
ZippyNH
It appears you are missing the part of the diverter that is on the underside of the hood....so it seals to the hood.......
Can you post a pic of the underside of your hood?!
Old Apr 28, 2014 | 06:09 PM
BoogieBear's Avatar
BoogieBear
Old Apr 28, 2014 | 09:15 PM
Javskies's Avatar
Javskies
That's looks awesome! Where did you get the aluminum?
Old Apr 29, 2014 | 06:59 AM
BoogieBear's Avatar
BoogieBear
home depot is used as trim/edging for sheet rock.
Old Apr 29, 2014 | 07:02 AM
BoogieBear's Avatar
BoogieBear
I used the stock foam blocking that comes on the hood. There's a 1/16 gap all around. So the foam sits on the ledge to seal the gap.
Old Apr 29, 2014 | 07:26 AM
soccerbummer1104's Avatar
soccerbummer1104
aluminum would be cheaper than stainless if it is just a cut and form piece with no welding.
Also easier to work with (IMO)
Decent adaptation mod for the budget conscious!
As for foam / better foam, try McMaster-Carr
It is where I order 99% of my hardware as they have about everything, excellent quality, and awesome prices on most things.
(it is a huge industrial supply company)
only problem you will have is being inundated with options and not knowing which to choose. haha. not a bad problem to have, but a problem none the less :P
http://www.mcmaster.com/#bulb-seals/=rqxe04
There is a link to the "weatherstripping" / Bulb seals section.
Everyone who is a DIY'er should give the site a browse. The more you dig, the more you will be amazed as to the options.
Also a great place to source those "red clips" if you every break one on your vacuum
Old Apr 29, 2014 | 07:32 AM
soccerbummer1104
Oh, and FYI, I use metal supermarkets for my metal when I do fab work.
Metal to make one of these in 6061 aluminum would run about $15 (for a one-off).
Order enough metal to make 100 of them and that drops to
~$5 / piece
Then it would take ~ 20-30 minutes per piece to make once you have a jig set up
-> ~$10 labor
add in 40% profit / overhead costs (electricity, property taxes, equip maintenance)
and you could ostensibly make these for ~ $21 before shipping and hardware and foam.
Old Apr 29, 2014 | 07:41 AM
Saltysalt's Avatar
Saltysalt
looks simular to my alta, which is over priced... i also have the plastic piece under the hood missing. good idea!
keep rolling with it
Old Apr 29, 2014 | 08:07 AM
BoogieBear's Avatar
BoogieBear
[QUOTE=soccerbummer1104;3922603]aluminum would be cheaper than stainless if it is just a cut and form piece with no welding.
This looks like a great link. I'll be getting 1/2" thick x 1" dense foam strip. Thanks
Old Apr 29, 2014 | 08:08 AM
BoogieBear's Avatar
BoogieBear
Thanks. I appreciate the support.
Old Apr 29, 2014 | 12:17 PM
thirdlobe's Avatar
thirdlobe
I would be interested in one as well. Keep us posted.
Old Apr 29, 2014 | 12:28 PM
BoogieBear's Avatar
BoogieBear
I'll see if i can get one out to you.
I just want to make a couple of them so i can get the hang of the tin snips or the dremel cutting disk. But you'll be next
Old Apr 29, 2014 | 12:43 PM
BoogieBear's Avatar
BoogieBear
will do, thanks
Old Apr 29, 2014 | 11:16 PM
Javskies's Avatar
Javskies
i call dibs if a third is made!
Old Apr 30, 2014 | 09:57 AM
BoogieBear's Avatar
BoogieBear
you got it man
Old Apr 30, 2014 | 10:25 AM
ashchuckton's Avatar
ashchuckton
Very nice DIY mod.
If I hadn't already spent money on my DDM one.....
Old May 1, 2014 | 08:07 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Hey, I take on in black. Looks damn good.
Old May 1, 2014 | 09:11 PM
PrplPplEtr's Avatar
PrplPplEtr
One in black, please and thank you.
Sent from my Moto X using NAMotoring
Old May 24, 2014 | 08:40 PM
Bulldog_Blue's Avatar
Bulldog_Blue
+3….
I'll take one also in Red if possible, (if not black is also ok) .Ready to send money via paypal!!!
