Drivetrain Alternative to NM Eng. Intercooler Piping?
Old Apr 11, 2014 | 01:12 PM
  #26
ra2fanatic's Avatar
ra2fanatic
Originally Posted by bster13
when i thought about the amount of surface area it takes an intercooler to cool down intake air, i did not think this small amount of surface area (remember, the inside of this product is smooth, no fins), nor the amount of time intake are spends exposed to this product was worth the $.
+1
Old Apr 11, 2014 | 03:09 PM
  #27
HorseWithNoName's Avatar
HorseWithNoName
Originally Posted by Rocket'89
Do these install in the existing factory silicone hoses replacing just the muffler?
Yes...
Old Apr 11, 2014 | 03:12 PM
  #28
Rocket'89's Avatar
Rocket'89
Right. But would installing a metal pipe, finned or not, into the two existing silicone hose couplers be similar enough to the NM solution which is also a hard pipe inserted into two silicone couplers? Food for thought.
I don't think the fins would provide much of a heat-sink affect either. Some perhaps, but not a lot.
Old Apr 11, 2014 | 03:17 PM
  #29
Rocket'89's Avatar
Rocket'89
I just received my Forge IC and Alta boost tube yesterday. After reading reviews, I am hesitant on installing the Alta boost tube. I can see the logic of a hard pipe being more durable or reliable over time compared to the silicone alternatives. It's just tough spending the money. I suppose at some point I just shouldn't be such a cheapskate. LOL.
Can't wait to install the Forge IC. Tune is next
Old Apr 11, 2014 | 03:26 PM
  #30
RobMuntean's Avatar
RobMuntean
You should have gotten the Forge Hot side, it is very solid. I've had it on for a year, and no issues or tears. Well worth it, for $150-160.
  #31
Rocket'89's Avatar
Rocket'89
Originally Posted by TwinCoopers
Yes...
What was your clearance like? Any issues with the fins rubbing other parts? Thx.
Old Apr 11, 2014 | 03:40 PM
  #32
HorseWithNoName
Originally Posted by ra2fanatic
+1
I'm thinking after owning two of the others, a nice metal cnc replacement vs hose or plastic pipe is an nice upgrade at a 3nd of the cost, if the pre-intercooler drops temp a 10th of a degree that's a free bonus.
I'm installing tomorrow...
Old Apr 11, 2014 | 03:44 PM
  #33
Rocket'89's Avatar
Rocket'89
I haven't found any pricing near that low for the NM discharge pipe. Otherwise I wouldn't be having this conversation. I would have bought it. LOL. I haven't opened the box yet. I can still look to see what is out there. I googled the heck out of this but could not find the hot side less than $220. I picked up the Alta for $100 less than that.
I have no doubt that I would be happy with the NM solution. I just didn't want to spend much more after picking up the Forge unit.
I'll keep looking. Any suggestions on where you can find that price point?
Old Apr 11, 2014 | 05:44 PM
  #34
RobMuntean's Avatar
RobMuntean
I haven't found any pricing near that low for the NM discharge pipe. Otherwise I wouldn't be having this conversation. I would have bought it. LOL. I haven't opened the box yet. I can still look to see what is out there. I googled the heck out of this but could not find the hot side less than $220. I picked up the Alta for $100 less than that. I have no doubt that I would be happy with the NM solution. I just didn't want to spend much more after picking up the Forge unit. I'll keep looking. Any suggestions on where you can find that price point?
I posted the link in this thread somewhere
Old Apr 11, 2014 | 08:59 PM
  #35
Rocket'89's Avatar
Rocket'89
My apologies. I did not read your reply close enough. You mentioned the Forge pipe, not a NM Eng. Yes, that pricing is consistent. I would love to find NM for that. Maybe the Forge pipe is better than Alta. Not sure. For now, I have to bite the bullet and use what I purchased. I went back and read the return policy of the site I purchased it from. They do not allow returns for a change of mind. If the fitment is not right, that might be a different story. I'll find out in a couple of days when I install it.
Cheers!
Old Apr 12, 2014 | 04:26 AM
  #36
HorseWithNoName
It seems too measured up perfectly in length and the overall diameter with the fins is actually just a little smaller, I’m install it today so I will give an update.
Old Apr 12, 2014 | 06:22 AM
  #37
PaScrambled's Avatar
PaScrambled
Has anyone tried to re-enforce the silicone tubes. I like the minimum connections of the one piece over NM 4 connection points. I'm thinking taking a Forge pipe and wrap fiberglass around the mid-section outside, thus preventing flex under boost. Shoot paint on it and you'll never notice it. Better yet carbon fiber for the un-limited budget crowd.
Old Apr 12, 2014 | 05:09 PM
  #38
HorseWithNoName
OK Guys, install the hot side resonator delete and Pre-intercooler cooling pipe.
It fits perfectly in the place of the OEM resonator with no cutting, you will need to purchase 2 hose clamps because the OEM clamps on the resonator will have to be broke off at the locking joints, the joints look like a jigsaw puzzle impression in the clamp and can be separated with a big flat head screwdriver for removal.
IMO, it work great as a resonator delete and the quality is excellent, I do feel a little better throttle response and the swoosh sound track of the turbo like the Alta on our other MINI. With regards to dropping the temp as a pre intercooler, based on running the ambient vs intake manifold temp numbers I don’t see a spread drop but it was 15 degrees hotter ambient after install. I do know metal piping does heat soak and I absolutely believe this will not with the cooling fins.
In summary, it’s another good option for deleting hot side down tube resonators.
Old Apr 13, 2014 | 02:23 PM
  #39
Tigger2011's Avatar
Tigger2011
Alliance Member
Gotta agree with TwinCoopers. Been running this pipe for about 10k miles and I've been really happy with it. When it comes to cost the performance gain you get from an intake muffler delete makes it's damned difficult to justify the cost of the NM unit.
Old Apr 14, 2014 | 02:56 PM
  #40
Panther MINI's Avatar
Panther MINI
I had the aforementioned pre-intercooler pipe installed on my previous MINI and I have to say, for around 50$ (including shipping) this pipe functions the same way the NM set does, hose - pipe - hose basically, the intercooler muffler has a smaller diameter than the rest of the piping so replacing it with the pre-intercooler pipe does the job of creating consistent diameter piping.
KinetechMW
Jan 22, 2016 09:04 AM
LAcooper
Sep 22, 2015 10:03 PM
HaveATank
Sep 16, 2015 08:32 AM
Mb460
Sep 14, 2015 05:50 AM
OutMotoring
Sep 8, 2015 06:27 AM
