Drivetrain Unichip dyno not so good. :(
Old Jun 11, 2004 | 08:56 AM
  #26
paulmon's Avatar
paulmon
Originally Posted by Galaxie500
Paul,
These are great, helpful posts. Thanks for the info and I know we're eagerly awaiting the new results. Hope the new dyno runs don't cost you too much money.
Cheers.
You and me both. I"m trying to get something setup to do data logging next time. I'll keep you posted.
Paul
Old Jun 12, 2004 | 11:25 AM
  #27
mattcoon's Avatar
mattcoon
Paul,
If the dyno numbers are right, it would seem that letting the ECU adapt to the Unichip might produce a long-term improvement and that for an instant extra power, just turn off the unichip. Until the ECU readapted to stock you would get more power. If this is correct it might be fun to have a switch to toggle off for a quick power burst.
Old Jun 14, 2004 | 08:53 AM
  #28
andy@ross-tech.com's Avatar
andy@ross-tech.com
Originally Posted by paulmon
He hasn't seen the dyno plots but suggest that I run the car for 3 runs (without Unichip) then plug the Unichip back in and drive around for 15-20 minutes then dyno again (with Unichip).
Did Randy give any indication as to WHY he thought that would make a difference?
Old Jun 14, 2004 | 09:01 AM
  #29
paulmon's Avatar
paulmon
Not really other than experience. However I was in my car so I couldn't devote myself 100% to the conversation.
I'm going to test again and see what happens from there.
Cheers,
Paul
Old Dec 7, 2004 | 06:36 AM
  #30
05JCWS's Avatar
05JCWS
Paulmon,
Any new, news on this? I am wondering if the fact that you have a modified ECU already contributes to this as well.
Old Feb 15, 2005 | 01:38 PM
  #31
andy@ross-tech.com
Have any other consumers dyno'ed before and after installation of the Unichip?
Old Feb 15, 2005 | 02:04 PM
  #32
greatgro's Avatar
greatgro
Originally Posted by dgszweda1
Paulmon,
Hey that's an interesting question. B/c the unichip modifies the signal and "tricks" the ECU into making more power, is it possible that the unichip could modify the signal a certain way which it thinks will make power yet b/c of a different ECU program (JCW or version other than what the Unichip was tuned for), the results are different than what was expected? Hmmm...thoughts anyone?
Old Feb 16, 2005 | 05:59 PM
  #33
Ryephile's Avatar
Ryephile
Here are two plots I did of a friends '02 MCS. The UNIchip was done afterwards, with about a half hour of adaptive logic learn time after a reset before doing the next dyno pull. Peak gains of 11Lb-Ft and 9HP. SAE corrected, of course
Cheers,
Ryan
Old Feb 17, 2005 | 06:26 AM
  #34
andy@ross-tech.com
Any real dynos?
Old Feb 17, 2005 | 07:21 AM
  #35
El Diablito Rojo-N20Mini's Avatar
Any real dynos?
Old Feb 17, 2005 | 09:44 AM
  #36
sanddan's Avatar
sanddan
Ryan,
Were you running the "B" map? I know Randy and Unichip say you need 100 octane gas for the "B" map but I've run that map for over a year on 92 octane without any problems. (Knock on wood).
After having V39 installed I ran without the unichip for a week to get a feel for the new software and then put the unichip back on. My butt dyno noticed the difference right off. It's still hard to say if it's worth the $$ but I like the fact it can be removed for visits to the dealer as I have had them refuse work based on having mods.
Dan
NYMADMINI
Dec 14, 2016 02:33 PM
eMINI of the State
Oct 2, 2015 03:12 PM
Brochacho
Sep 29, 2015 10:24 AM
jennster
Sep 28, 2015 06:19 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
