Drivetrain ARP head studs worth it?
Old Mar 27, 2014 | 10:03 AM
FlynHawaiian's Avatar
FlynHawaiian
Are arp head studs worth it? Or are the factory ones good enough for an aftermarket head? FelPro also makes head bolts would those be better than the factory ones?
I cannot image there is much of a difference on these bolts, but I could be wrong?
Old Mar 27, 2014 | 10:49 AM
xgpguy's Avatar
xgpguy
If you track the car they are better if your changing the head. They are stronger.
Old Mar 27, 2014 | 11:01 AM
two250's Avatar
two250
If you're installing an aftermarket head I would do the studs also. I don't know if it's really required on the MINI but they hold much better than stock bolts. I have them on my F250.
Old Mar 27, 2014 | 11:09 AM
OCVeloman's Avatar
OCVeloman
I have them on my 2006 F250 too lol. better to have them and not need them than vise-versa. By the way, that's awesome. We have the same cars with reversed colors....
Old Mar 27, 2014 | 11:36 AM
ZippyNH's Avatar
ZippyNH
Want vs need....
So many performance parts are sold on owners desire to have "the best" when the stock has NEVER shown an issue. I bet the ARP are stronger in every way....but simply new quality headbolts are fine for 99% of the folks here.....
I would suggest (IMO) that reusing stock bolts are an iffy thing....a good eye might be able to spot elongation/stretching....but if in doubt, just junk them.
Old Mar 27, 2014 | 12:36 PM
daonlyillwiz's Avatar
daonlyillwiz
ARP head bolts are EXCELLENT. the advantage of using them is that they wont stretch. stock bolts will stretch. PLUS you are not supposed to reuse stock bolts because when they are torqued down they stretch a little. so it is recommended that you get either new OEM bolts OR ARP because they wont stretch unless you are running really high boost 34psi +
Old Apr 5, 2014 | 04:49 PM
FlynHawaiian
Do they make new studs for the intake manifold as well? If not any recommendations on replacements for the mini? I need new ones for my new head =)
Old Apr 5, 2014 | 06:32 PM
daonlyillwiz
What happened to the stock ones ?
Old Jun 30, 2018 | 12:35 AM
blue al's Avatar
blue al
Can you reuse the Arp on a different block ?
Not lifting and refitting heads
But say n14 1st then N18
Are they extract-able ?
Old Jun 30, 2018 | 06:45 AM
cornjuice's Avatar
cornjuice
plenty of folks pushing upward of +23psi without head bolts.. OEM rod bolts are cheap AF though; change those.
Old Jul 1, 2018 | 10:32 AM
downshift1's Avatar
downshift1
ARP offers uniform clamping force that cannot be guaranteed by the stock bolts that are torque to yield.
You can reuse them and for the few extra $ over buying all new stock bolts from Mini it's cheap insurance.
Old Jul 5, 2018 | 01:30 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Stock head bolts held at 24 psi for me but as soon as I went to 25 psi the head started lifting. No such issue with the ARP studs. N14 and N18 are the same.
Old Jul 5, 2018 | 02:36 PM
Dave.O's Avatar
Dave.O
ARP studs are a must for higher HP applications. Are they good? Yes, every race team in many motor sports use them for a reason. OEM bolt are one time use torque to yield, stretch are not that strong. If your putting a new head on your car with a new head gasket they are cheap insurance over weaker OEM bolts.
Old Jul 5, 2018 | 11:53 PM
blue al's Avatar
blue al
I'm starting off with n14 motor and willl end up n18
Can the studs be pulled from block and reused on another block ?
Old Jul 6, 2018 | 05:37 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
You could but why bother? $180 for ARP, subtract $35 for the factory bolts youll have to buy to replace them with is $145. Replacing the studs one at a time might keep you from having to replace the head gasket on the N14 but if it leaks... now your looking at cam bolts, head gasket, having to retime the engine, yada, yada. Not really worth it with what can go wrong. Or are you planning an N14 to N18 engine swap?
Old Jul 7, 2018 | 04:16 AM
blue al's Avatar
blue al
Too many engines and plans
Nothing cast in stone, as my n14 is so new and fresh
Planning to push it hard but not not to destruction, was considering the studs as insurance but need to see extensive reuse as you have pointed out for the math to work
I've got Rcz r lump on ice
It seems too much of of a project to swap out completely at this stage
Perhaps if a cost effective stand alone was available
Manifold and turbo swap seem to be the low hanging fruit, and will happen soonish
But the bottom end seems to be where most of the goodness is
Happy to enjoy the journey before trying to build a monster in one hit
Last edited by blue al; Jul 7, 2018 at 04:18 AM. Reason: Other bits to finish 1st including brake upgrades
Old Jul 7, 2018 | 01:49 PM
Revolution Motor Works's Avatar
Vendor
the big deal is: They are re-usable vs the 1x only use stretch bolts.......now take the costs into account and you have your answer (even if you run lower boost)
Filmy
15
Jun 6, 2023 06:27 AM
co0p3r
Sep 18, 2015 01:43 PM
tech12
Sep 16, 2015 05:30 PM
