Drivetrain Where to get boost reading on 2013 MCS?
Old Mar 18, 2014 | 01:12 PM
miniforozzie's Avatar
miniforozzie
I need to find a boost reference point for my '13 MCS and found this. Only problem it says its for an N14. Will it work with my N18 engine? If not, any ideas?
BSH boost tap
Old Mar 18, 2014 | 01:23 PM
The Patagonian's Avatar
The Patagonian
Google Forge Motorsport boost gauge adapter....they are about £25 but can also be found on eBay.
It fits under the air box where there is an existing takeoff point.
Old Mar 18, 2014 | 01:29 PM
DneprDave's Avatar
DneprDave
The BSH Dual Boost Tap will not work on an N18 engine, as the N18 engine does not have the head cover to throttle body PCV hose like the N14 engine does.
Forge, Alta and Cravenspeed have boost taps that will work on an N18 engine.
Dave
Old Mar 18, 2014 | 01:34 PM
cerenkov's Avatar
cerenkov
I believe the NM Engineering (Neuspeed) will work:
http://www.nm-eng.com/291/11/0/1458/...tap.html#popUp[products]/1/
Old Mar 18, 2014 | 10:30 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Yep, cerenkov is correct. NM, Alta, Craven all have similar adapters. If you are installing a mechanical gauge this will get it done. The real time data from the Manifold Air Pressure sensor (where this adapter is installed) is also available via obd2.
cerenkov
Apr 24, 2018 07:47 AM
jacobj
Aug 24, 2015 06:49 AM
kyungmanpark
Aug 23, 2015 07:26 PM
Getrieben
Aug 15, 2015 09:09 PM
clintmeister
Aug 12, 2015 11:11 AM
