Drivetrain Disappointed with my upgrade
Old Mar 10, 2014 | 07:37 AM
  #26
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by IQRaceworks
I think it's pretty obvious that something is wrong. You need to go back and check everything you changed or replaced. Did you accidentally pull off or crack a vacuum line fitting? Are the intercooler clamps and seals both installed correctly? Are there any loose plug wires?
Did you do the work, or did you have a shop do it? With all of the things that have to be removed/pulled off/and reassembled......odds are you have something that didn't get put back together right. I'm betting on a cracked vacuum hose or fitting.
- Cracked line to the FPR on the fuel rail will do this. It runs from Right side plenum then under IC.
molala
Oct 2, 2015 01:53 PM
minimofo
Sep 30, 2015 12:26 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
