Drivetrain HELP!! Engine light on with SIX codes (0012, P0015, P0055, P0300, C342D, and C3064)
Old Jan 23, 2014 | 10:45 AM
Clubman_mini's Avatar
Clubman_mini
I have engine light on since yesterday and my mechanic checked my 2010 clubman. There are 6 codes. They are P0012, P0015, P0055, P0300, C342D, and C3064. Usually when staring, RPM goes up & down, and later it's ok, but sometimes engine shuts off. What shall I do? Can I drive for a while? Either MINI or BMW dealer is hundreds miles from me. Please help :(
Old Jan 23, 2014 | 04:21 PM
bmx045's Avatar
bmx045
check oil level firstly. the camshaft codes and 0055 can cause the p0300(pending misfire). 0055 is a h20s heater fault- which is o2 sensor heater circuit fault. that undoubtedly means you need a new o2 sensor, bank 1 sensor so I believe it's the one on the downpipe. does your car have the death rattle? poor timing chain tension can cause the camshaft codes, but so can low oil pressure. the o2 sensor fault (which is more than likely entirely unrelated to the others) will cause significant drivability issues and the rpm fluctuations.
Old Jan 23, 2014 | 07:14 PM
Clubman_mini
Thank you very much. Do you think I can still drive to the dealer around 130 miles from my home.
Old Jan 24, 2014 | 07:47 AM
bmx045's Avatar
bmx045
it's probably best not to drive it.
Svejk
Feb 24, 2019 12:18 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
