Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
#351
Meth injection is a huge plus for those tuning their Mini's, it keep combustion chambers cooler which allows you to choose a more aggressive tune without worrying about melting your piston landings. It will lower your intake temperatures by as much as 20 degrees below ambient.
Lowers intake more than that. Sometimes I'm seeing almost 30F below ambient, so that really is about 50F below what you would see by just running an intercooler. It really is dependent on temperature and humidity. On hot, dry days I see the greatest effect.
#352
I could only imagine driving from SoCal to Las Vegas when it's 100 degrees fahrenheit outside running even 30 below, I'd be smiling!
#353
John was that your white CMS with the license plate to the right? Had no idea yours was that modded -- definitely a sleeper. Glad to hear you experience the same throttle effect. I haven't gotten the SPS but didn't think I needed it if I'm sticking with just Stg1 for now. I want to do some suspension work before going Stg2.
#354
#355
John, were you able to get new spark plugs like Nick suggested? If you did, is your car running better? Nick installed them for me as I got tuned last Saturday.
#357
Honestly just finished putting them on. Just started they car. Seems fine. Going on test ride to see how it goes. They are the ILKR8E6.
#358
#361
#362
#364
Maybe I missed the answer, if you have the tune installed and need to go to the dealer and they do a firmware upgrade will then tune then be set back to factory? I'm not asking a factory warranty question, more like if your windows need the firmware reload which I did need to have done on my 09 or something like that. If the answer is yes, if I purchase the tune, can I also purchase a device like other companies use to reload thru my OBD?
#365
#366
You need to buy a Switch, so you can toggle through your maps. According to Manic, they are $200 US, but they are out for a couple weeks.
#367
If the dealer reflashes the ECU, the Manic tune will no longer exist. You will need to go back to the Manic dealer and have them flash it back.
There is no devise you can buy (affordably) that will allow you to reflash the ECU to the Manic tune.
This info is confirmed by Manic.
#369
Switching it to the stock setting is just that... just a switch. You can switch it back and forth to any map loaded at will. It doesn't rewrite anything.
#370
To be clear, Manic loads the ECU with 4 tunes:
1. Stock Tune
2. Performance tune A - Conservative tune
3. Performance tune B - Everyday tune (provided you are running with the gas, meth, etc. it was tuned with)
4. Performance tune C- Race tune (race gas, meth, whatever it takes to keep the mini happy at the more aggressive tune)
1. Stock Tune
#371
That is the answer I was looking for. Thank you. Until we can flash locally and being there is no dealer in my city I will wait.
#374
hahaha. no worries man! The only thing that sucks is being at work today. ha!
No matter what mode you are in, when the dealer flashes the ecu, the entire thing gets written over. So, you would need to have the Manic dealer reflash it back.
