Drivetrain How much boost exactly.....?
Old May 17, 2004 | 07:31 PM
EmCeeEss's Avatar
EmCeeEss
.... does the stock pulley make, (i.e. 7 lbs?)...
also, how much boost does the 15% reduction pulley make? i appreciate your help.
(side note: what kind of oil do you guys use in YOUR minis?)
Old May 17, 2004 | 08:29 PM
MiniPilo's Avatar
MiniPilo
I think stock is about 14 lbs.. 15% is about 16-16.5
I use Castrol Syntec.
Old May 17, 2004 | 08:33 PM
VmpyrDavid's Avatar
VmpyrDavid
Minty Fresh
Stock is 11.3 pounds.
Old May 17, 2004 | 08:36 PM
cdconsor's Avatar
cdconsor
That agrees with my experience. 4th gear, WOT, mobil 1 (but switching to redline when I hit 10k)
Old May 17, 2004 | 08:42 PM
Ryephile's Avatar
Ryephile
according to my Auto Meter mechanical boost gauge tapped into the fuel pressure regulator...
~12.5 PSI bone stock at 6950 RPM
~19 PSI with 15% pulley at 7200 RPM
The MAP sensor seems to read lower (according to Andy@rosstech), and I'd tend to trust the MAP over the cheap Auto Meter gauge.
Old May 17, 2004 | 08:45 PM
ipmasqman's Avatar
ipmasqman
Helix says that you can get an added 5 lbs with a 15% reduction. Eric is the most honest mechanic I know. :smile:
He does not over estimate the numbers.
Helix Pully Reduction torque gains are 5lbs
I use Mobile one between every dealer change. I change my oil twice as much as recommended.
Old May 18, 2004 | 04:22 AM
jcolletteiii's Avatar
jcolletteiii
This agrees with what I've seen. Max boost @ WOT 12.3 w/ stock pully. Measured at fuel pressure regulator.
-joe
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
