Drivetrain Shift linkage housing
Old May 17, 2004 | 10:09 AM
Pebblecrusher's Avatar
Pebblecrusher
For those that have installed the short shift kits (the extension piece kit), have you noticed any problems with the lid of the housing being not there? How far out of the housing does it stick?
Just wondering why no vendor has offered a replacement lid, or even if it is needed. I'm the type of guy that likes things to be complete, and not having the lid on the housing means it's not complete.
Of course, not being able to get the linkage apart pretty well stopped me from completing the mod (along with finding out I have the 03 style on my 04). :smile:
Old May 17, 2004 | 10:42 AM
MiniPilo's Avatar
MiniPilo
The B&M SS Kit keeps the factory lid. And will fit on an 03
Old May 17, 2004 | 11:05 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
There was more dirt/dust/particulate matter inside my lid than outside. Maybe the lid is designed to keep stuff in.
Old May 17, 2004 | 11:32 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
2 months of SS and no problem without the housing cover. :smile: The heat shield protects the housing quite well from dirt, etc...
Remember, the key is to rotate the socket of the joint laterally and superiorlly until it disengaged from the ball of the shifter shaft. Use a flat head screw driver and find a point of leverage to rotate the ball-and-socket joint. DO NOT PULL!
Both Alta and B&M retain the housing cover. As for the other style that adds a link,
MINI Mania sells it with a cover.
_________________
Old May 17, 2004 | 11:44 AM
Pebblecrusher
Ok, a little homework goes a long way. Did not know that Alta and B&M kept the housing cover.
"... rotate the socket of the joint laterally and superiorlly..."
Wish I went to med school, cause then I wouldn't have to go to http://www.m-w.com to figure this out. :smile: I got the time to research some more while I wait for the part to get back from Helix.
Rohdeandschwarz
May 16, 2019 08:59 AM
Sep 10, 2015 11:55 AM
nayr924
Sep 8, 2015 02:41 PM
SneedSpeed
Sep 2, 2015 05:34 AM
Sep 1, 2015 04:02 PM
