Drivetrain Anyone read negative boost?
Old Sep 20, 2013 | 01:12 AM
johntotah94's Avatar
johntotah94
Driving normally my Scan Gauge II reads -0.7 BST
Anyone else read negative boost on any of your gauges.
This is normal right?
Old Sep 20, 2013 | 03:31 AM
cerenkov's Avatar
cerenkov
That's normal. It's also why some people think a boost gauge is not very useful because it usually reads zero (or vacuum) unless your really into the throttle.
Personally I like'm :thumbsup
Old Sep 20, 2013 | 04:29 AM
MiniWii's Avatar
MiniWii
Like he said above that is normal. It's called vacuum, you'll see some vacuum at cold idle and in between shifts w/ boost.
Old Sep 20, 2013 | 08:16 AM
InjectedGT's Avatar
InjectedGT
You're only going to read boost when the turbo is spooled up and producing boost. Not sure how anyone thinks a boost/vac gauge properly showing vac when out of boost could deem it "not very useful" cerenkov?? It's showing exactly what the conditions are. Doing it's job properly.
Old Sep 20, 2013 | 08:50 AM
cerenkov's Avatar
cerenkov
I could have worded it better. I'll try again...When people are installing actual physical gauges in the car and only have room for maybe two gauges, other parameters might be more ?important? (read: very subjective) like coolant temp or oil pressure/temp, etc. I understand that the OP is using a multifunction device so it doesn't pertain to him directly. I was just making an observation.
Also I believe that I said the gauge was working properly.
Like I said above, I personally like boost gauges and when I use DashCommand the skin I display has boost, IAT and coolant temp.
Old Sep 20, 2013 | 09:18 AM
InjectedGT's Avatar
InjectedGT
Gotcha. I'm still baffled by MINI/BMW's blatant disregard for any gauges that just about every car on the road has anymore. It's like they assume their buyers are mindless "wives" who know nothing about the car and just think "when it's too late, we'll throw a light on and hope they know enough to pull over".
So with all that said, the main screen on my Torque app shows coolant temp, IAT, Boost. The unavailability of oil pressure annoys me still, but coolant temp in itself is a gauge I can't, for the life of me, understand why they would ever exclude from the stock cluster.
Old Sep 20, 2013 | 11:07 AM
NewCooperFanatic's Avatar
NewCooperFanatic
Psh think that's bad....new BMWs don't even have dip sticks anymore!
Old Sep 20, 2013 | 11:20 AM
cerenkov's Avatar
cerenkov
I just read that elsewhere too, but you know our dipsticks are horrible anyway. When you have to consult the owners manual on how to read a dipstick, there's something wrong. I still don't know if I'm reading it correctly!
Old Sep 20, 2013 | 11:21 AM
InjectedGT's Avatar
InjectedGT
Now... I've been a BMW fanatic for quite some time now. And I always laugh at all the oddball, quirky things they do. Most of them are fun to make fun of. Like having a warning light for every single thing on the car, because apparently a lot of wives buy BMW's? :P
But please PLEASE tell me you're joking about not being able to keep tally on your oil. I'm sure there's SOMETHING.
Old Sep 20, 2013 | 12:16 PM
NewCooperFanatic
Now... I've been a BMW fanatic for quite some time now. And I always laugh at all the oddball, quirky things they do. Most of them are fun to make fun of. Like having a warning light for every single thing on the car, because apparently a lot of wives buy BMW's? :P But please PLEASE tell me you're joking about not being able to keep tally on your oil. I'm sure there's SOMETHING.
Yea, when the light comes on haha......or if you have I-Drive, the computer tells you the oil level.
You can also use the stock to toggle between settings to check on the dash.
They're not thinking with their dip stick Jimmy! Hahahaha. :P
Old Sep 21, 2013 | 04:32 AM
bmx045's Avatar
bmx045
vacuum is very useful, you'll know if you have a boost leak that way or a hose popped off..... closer to 0 it reads the less the manifold has of vacuum, that it SHOULD have.
Old Sep 21, 2013 | 09:26 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
N14 and N18 are different. As mentioned above, the N18 only shows vacuum when cold. Once it warms up the throttle plate opens and the VANOS system controls the intake. The N18 will be right around 0 psi most of the time, it only boosts when you're on the throttle hard. I see this both on my boost gauge and data logging with the Torque app.
Old Sep 28, 2013 | 04:24 PM
HorizonBLueN18's Avatar
HorizonBLueN18
VANOS is the bmw equivelant of variable valve timing isn't it? What would be the point for it to keep vacuum as close to zero as possible?
Old Sep 28, 2013 | 07:50 PM
MinMin2010's Avatar
MinMin2010
Here is a good example while setting at idle.
Old Sep 28, 2013 | 10:21 PM
SPRINTCARS's Avatar
SPRINTCARS
Just curious... The boost gauge,when its at idle, is it rock steady or does it wiggle a bit ?
Old Sep 29, 2013 | 06:24 AM
MinMin2010's Avatar
MinMin2010
It does wiggle just slightly.
Old Sep 29, 2013 | 07:51 PM
InjectedGT's Avatar
InjectedGT
Your RPM is constantly fluctuating as is your vacuum ever so slightly. You don't see it on your tach because a buffer is built into the computer so it shows a smooth, steady number.
Old Sep 30, 2013 | 10:55 AM
squawSkiBum
Moderator
Yes it is the BMW variable valve timing and lift system.
The point of variable intake valve lift is to eliminate the pumping loss at low RPM caused by the partially opened throttle plate. Intake manifold vacuum is the engine sucking against that restricion - intake valve open, piston going down, and throttle plate closed or partially open. Opening the throttle plate all the way and managing air intake with variable valve lift eliminates the loss and results in very low vacuum. This applies whether the engine is turbo/supercharged or not.
One hypermiling technique for cars with a throttle body is to accelerate using top gear to keep RPMs low and WOT to eliminate the pumping loss, of course this only works with a manual transmission.
Old Sep 30, 2013 | 10:58 AM
squawSkiBum
Moderator
You can damp out the wiggle in the boost gauge by stuffing a little bit of cotton into the tubing just before the input to the gauge.
Old Nov 3, 2017 | 12:00 PM
Bnourai's Avatar
Bnourai
I am on dash command too and eaven if I'm on hard driving I only get negetive boost
Old Nov 3, 2017 | 02:24 PM
Papi Wardrobes's Avatar
Papi Wardrobes
@Bnourai so you obviously have a boost leak ... do you read boost through the ECU , or do you have a boost tap and read it via vacuum ..
Old Mar 29, 2018 | 04:45 PM
Bnourai's Avatar
Bnourai
Wow man I am so far off on replying only 4 month lol.no boost tap it is via ecu.
Ben
Old Sep 16, 2018 | 06:23 PM
madcanvis's Avatar
madcanvis
Just got DashCmd
and it seems the gauge uses a reversed number line ie: 0, -1, -2,... for ease of reading. This is all new to me.
im getting ~ -7 at idle and -15 at 5k.
Sound about right?
17% UP, 380cc injectors, JCW CAI (paper), JCW exhaust (resonator delete)
why start new when you can redirect a thread. Ammirite
Old Jun 10, 2019 | 03:32 PM
Zeek's Avatar
Zeek
Soooo, my 2013 S has been reading -0.7 BST at normal idle for 6 years. This week it started showing 0.0 or 0.1 at idle. At full throttle, instead of peaking around 14 it goes to 16. Would this be the boost sensor? If so, is it the one on the intake?
Filmy
15
Jun 6, 2023 06:27 AM
12R58JCW
General Discussion
17
Jan 10, 2016 11:26 AM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
