Drivetrain aem water meth injection kit. which fluid?
Old Aug 20, 2013 | 11:57 AM
RA082324's Avatar
RA082324
just got an aem wmi kit.
wondering what i can use for fluid, for instance, can i run snow perfs boost juice in a non snow perf kit like aem?
or will i have to mix my own?
im looking to stay around a 50/50 mixture, definitely not exceeding 60m/40w.
any suggestions/ideas are appreciated.
Old Aug 20, 2013 | 12:01 PM
ZippyNH's Avatar
ZippyNH
Some folks may suggest blue washer fluid....works in a jam, but I caution you, it is usually made with water with lots of minerals....that is why you get crusty stains where it dries...
My suggestion...either buy the makers premixed stuff, or mix you own with distilled water.
Old Aug 20, 2013 | 12:43 PM
RA082324's Avatar
RA082324
ive heard the blue dye, as well as the minerals can clog the system. not sure how dye would do that, but the minerals i can understand. theres a place locally that sells pure meth, so i may just make my own. id still like to know others opinions as well.
im not sure if aem makes a premixed fluid, but i dont see why the boost juice would be an issue unless its just one of those things.
Old Aug 20, 2013 | 12:51 PM
killerfox's Avatar
killerfox
just buy it locally, I get it in 5 gal. containers. R53's love 100% meth.
Old Aug 20, 2013 | 01:37 PM
RA082324's Avatar
RA082324
are you sure about that? ive read using 100% in any application will do more harm than good. i was under the impression that a proper mixture was necessary to get the best result, as well as not to damage any components.
also keeping into consideration that the tank is going to be in the cabin. i dont allow any smoking in the car, but theres just something about a gallon of highly flammable undiluted liquid splashing around behind me that rubs me the wrong way. a 50/50 mix is no safer, but you get what im saying lol.
Old Aug 20, 2013 | 01:57 PM
killerfox's Avatar
killerfox
Not sure were you read about 100% doing harm to your motor but to my knowledge that's not true. I was running 100% in my Aquamist system for my R56 for 2 years without issue. I had a 2 gallon system in my car. I have personally seen on a dyno, R53's getting tuned and they all did better with 100% meth. I would check out http://www.aquamist.co.uk/vbulletin/index.php?
http://howertonengineering.com/ (the pictures of the dual tank setup in clubman on this site are my car)
Old Aug 20, 2013 | 02:01 PM
ra2fanatic's Avatar
ra2fanatic
Likewise, I initially ran like a 70m/30w mixture, but now only run 100% VP1 methanol with my HFS-4 Aquamist system
Old Aug 20, 2013 | 04:59 PM
BlwnAway's Avatar
BlwnAway
You can use anybody's pre-mix or mix your own or even 100% if you're just using it for cooling, but if you're tuned for it you need to stick with the same mix %, no matter what or whose it is in order to keep from possibly doing damage.
Basiclly 90/10 or 10/90 if you're tuned specifically for it, thats what you need to stick with.
Old Aug 20, 2013 | 11:09 PM
RA082324's Avatar
RA082324
ok thanks for the help guys.
Old Mar 4, 2019 | 10:14 AM
Beka_2JZ's Avatar
Beka_2JZ
50/50 works Perfect. one part of it (water) makes IAT temps lower and another makes your fuel octane rise. also it IS the the best bang for a buck.
Old Mar 6, 2019 | 10:55 AM
IQRaceworks's Avatar
IQRaceworks
1. 100% meth is nasty dangerous if it ever catches fire.
2. Most people do a 50/50 mix with DI water because water actually cools better than meth, AND at 50/50 it's not flammable.
As far as what fluid to you......check your area to see if there are any local race shops that sell fuel. I buy VP M-1 100% methanol from a local shop for around $5 a gallon....so $2.50 a gallon after mixed with de-ionized water.
IQRaceworks
This. Water for cooling. Meth for higher octane. Also....it's not going to catch on fire and burn your car down if you have a leak and/or get in a crash.
Old Mar 6, 2019 | 01:11 PM
BlwnAway's Avatar
BlwnAway
Ouch.. My local supplier has VP 100% for 3.15 gal. + tax.right now
I buy a couple of 5 gal containers at a time since I'm running a 75/25 mix.
Old Apr 30, 2019 | 06:37 PM
putttn's Avatar
putttn
What mixture if just for cooling and not tune? I heard that windshield fluid was fine?
Old Apr 30, 2019 | 07:00 PM
BlwnAway's Avatar
BlwnAway
The problem with washer fluid is the dye that makes it blue, it can crystallize and flake to clog nozzles and pumps.
This is why it's ok to use in a pinch, but you always want to use a regular W/M mix after, to flush the system.
Personally, for cooling I'd look at anywhere from 50/50 to 75/25 water to meth, the water is what does most of the cooling.
Old May 1, 2019 | 05:46 AM
putttn's Avatar
putttn
Where do you buy pure Methanol?
Old May 1, 2019 | 07:29 AM
BlwnAway's Avatar
BlwnAway
Local race gas or solvent supplier.
patsum
26
May 29, 2021 06:29 PM
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
