Drivetrain What is "Boost"?
Old Aug 15, 2013 | 03:37 PM
Panther MINI's Avatar
Panther MINI
What is "Boost"?
Ok yes i'm a newbie when it comes to modifications but even after reading other threads and trying to research it, i still don't understand what "boost" is. Can someone or some people explain what it is and what it does? Greatly appreciated
Old Aug 15, 2013 | 03:47 PM
R60All4's Avatar
R60All4
Its to do with Turbocharged/supercharged vehicles.
Mini Coopers= No boost
Cooper S/JCW/GP= Boost
Old Aug 15, 2013 | 03:50 PM
R60All4's Avatar
R60All4
Check out some info on Turbo chargers, forced induction, super chargers. Not being rude, just some key terms to help out. Videos are also a helpful source of information.
Hopefully that can get you a good starting point
Old Aug 15, 2013 | 03:51 PM
ZippyNH's Avatar
ZippyNH
Ask Google or wiki....
Some good descriptions...
Old Aug 15, 2013 | 04:07 PM
Coop-a-Loop's Avatar
Coop-a-Loop
Turbo boost=positive manifold pressure in engines=forced induction=efficiency
Old Aug 15, 2013 | 04:13 PM
ZippyNH's Avatar
ZippyNH
Or slang...
Boosting a car=stealing a car....
Old Aug 15, 2013 | 04:27 PM
Panther MINI
yeah typed "boost in cars" and it came up with results for boosting cars
yetti96's Avatar
yetti96
Air that is introduced into the motor for the combustion process is boosted, or pressurized to a pressure higher than that of atmospheric pressure.
Old Aug 15, 2013 | 04:32 PM
Panther MINI
Ok so after a quick trip to wikipedia boost refers to, im guessing, the amount of air pressure greater than atmospheric pressure going into the engine?
Panther MINI
So what is the average boost on a stock turbocharged r55?
Old Aug 15, 2013 | 04:46 PM
Panther MINI
And how exactly does boost create more power?
Old Aug 15, 2013 | 04:47 PM
Braminator's Avatar
Braminator
Maybe this will help you to better understand boost.
http://auto.howstuffworks.com/turbo.htm
Old Aug 15, 2013 | 04:58 PM
Panther MINI
Great article, very informative Braminator
Old Aug 15, 2013 | 05:26 PM
Braminator's Avatar
Braminator
I hope it makes more sense now.
Old Aug 15, 2013 | 05:39 PM
Panther MINI
I'm trying to figure out what the average boost would be on my stock clubman s, anyone have any data or idea on what it could be?
Old Aug 15, 2013 | 05:43 PM
Beachnmini's Avatar
Beachnmini
I thought I read about 14lbs on here somewhere
Old Aug 15, 2013 | 05:49 PM
Braminator's Avatar
Braminator
approx 11.6 psi.
Old Aug 15, 2013 | 06:10 PM
Panther MINI
And what kind of mods increase boost? For example, air discharge pipes, CAIs, charge pipes etc etc?
Old Aug 15, 2013 | 06:20 PM
richardsperry's Avatar
richardsperry
None of those. Boost pressure is controlled by the ECU. Getting the ECU tuned is what will increase boost pressure.
Old Aug 15, 2013 | 06:29 PM
Panther MINI
Ahh I did not know that, i saw a couple people saying mods helped with boost pressure so in my mind i thought mods add boost, silly me
Old Aug 15, 2013 | 06:33 PM
Braminator's Avatar
Braminator
This will help
Old Aug 15, 2013 | 06:34 PM
cerenkov's Avatar
cerenkov
Remember that as you increase boost (pressure) you increase stress on your engine, increase it too much and you start breaking stuff.
Using an OBD scanner and an iPhone app I read a max boost of 13 psi. Don't know the accuracy of the measurement though.
Old Aug 15, 2013 | 06:36 PM
RobMuntean's Avatar
RobMuntean
Originally Posted by richardsperry
none of those. Boost pressure is controlled by the ecu. Getting the ecu tuned is what will increase boost pressure.
+1
Panther MINI
And is there a certain equation or rule of thumb as to how boost increases performance such as in horsepower or throttle response?
Old Aug 15, 2013 | 06:38 PM
cerenkov's Avatar
cerenkov
Some people claim that bolt on mods help with the turbo spooling faster (sooner), that's debatable. Mostly it's sound and bling.
