Drivetrain 15% Pulley Removal
Old Jul 20, 2013 | 07:41 PM
purplehaze05mcs's Avatar
purplehaze05mcs
15% Pulley Removal
If I decide to replace my 15 with a 17, can I remove my existing 15% without jacking up the engine again? Does it have enough wall clearance to take out my existing 15? Has anyone done this before?
Old Jul 20, 2013 | 08:29 PM
Da_Ghost's Avatar
Da_Ghost
Pretty sure it would be a pita to access the pulley without jacking the engine. I can't imagine removing the bolts and torquing them from there.
Old Jul 20, 2013 | 08:54 PM
Muguerza's Avatar
Muguerza
You are better off buying a crank pulley with a 2%. The crank pulley is accessible right through the side of the car and you dont need to jack up the engine
Old Jul 21, 2013 | 08:09 AM
jhiggs26's Avatar
jhiggs26
Yes you can with manual transmissions. Tight but workable.
Jeremy
Old Jul 21, 2013 | 08:56 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I would also add that you are not removing a stock pulley. So a stock pulley removal tool will not fit your 15% pulley you will be removing.
Other techniques are involved.
Old Jul 21, 2013 | 09:17 AM
Braminator's Avatar
Braminator
If its an aftermarket pulley you should not need a pulley remover.
Old Jul 21, 2013 | 10:09 AM
peter almeciga's Avatar
peter almeciga
2003 mini cooper man after I did every thing on my mini a week later the check engine soon light came on any ideas how to make it go off.
Old Jul 21, 2013 | 10:20 AM
Muguerza's Avatar
Muguerza
Go to your local auto parts store and ask them to check what codes your ecu is throwing out, that should tell you whats going on
Old Jul 21, 2013 | 10:27 AM
-=gRaY rAvEn=-
Moderator
lol, thinking of JCW's.
alistaircookie
Oct 8, 2015 10:52 AM
greekzilla
Aug 23, 2015 03:44 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
