Drivetrain R56 Diverter Valve Failure and Replacement Options
Old Jan 31, 2017 | 01:16 PM
  #26
manescu's Avatar
manescu
Is a relearn needed after DV replacement
Does anyone know if a ECU relearn or reset is necessary after a DV replacement?
Old Jan 31, 2017 | 01:18 PM
  #27
johntotah94's Avatar
johntotah94
No. I just unplugged the old one and plugged in the new one. Worked right away.
Old Feb 9, 2017 | 12:10 PM
  #28
gustavovon's Avatar
gustavovon
Guys, some one know if the oem diverter was upgrade ? Ecstuning is selling a DV with a new design, looks like a piston.
https://www.google.com.br/imgres?img...act=mrc&uact=8
http://www.rmeuropean.com/Images/Big...5B8CED1F-2.jpg
About the vag upgrade ... You are using still this upgrade ? I saw the thread that czar talk abouts the leak, but it was on the 710D, i dont know if the 710G have the same problem.
About the alta spring on vag internals or oem DV. I read here that in some situations could cause surge, is that right ?
Old Feb 9, 2017 | 01:32 PM
  #29
https://www.northamericanmotoring.co...christmas.html
11658636606 is the latest design
https://www.ecstuning.com/Search/SiteSearch/11658636606/
Below 11657593273 was the older design, the design before that the diaphragm tended to crack.
Old Feb 9, 2017 | 04:17 PM
  #30
gustavovon's Avatar
gustavovon
Thanks Ecs ! This new design is a piston ? Anyone are using adn have some feedback ? I already buy, just wainting for test.
Old Feb 9, 2017 | 04:36 PM
  #31
yesti's Avatar
yesti
Just swapped my old version for the new. My diaphragm wasnt broken yet. The new one cuts the yoyo when going on-off boost from multiple to one time, if that makes sense. It doesn't eliminate it like a stiffer spring would, and should keep factory mpg.
Old Feb 10, 2017 | 12:29 AM
  #32
gustavovon's Avatar
gustavovon
Yesti, sorry i didnt understand. Are you liking this new one ? It handle more boost ? I bought the alta spring too, do you think it is a good combo ?
Old Feb 10, 2017 | 04:54 AM
  #33
Welcome.
Yes, it's been revised a couple times. That's the latest. They got away from that diaphragm version.
Old Feb 10, 2017 | 04:55 PM
  #34
yesti's Avatar
yesti
I like the new one. Remember this is the OEM replacement valve meant for a stock engine/psi. That being said I am running peak of 20psi and it handles it fine. I did not replace the spring with a stiffer (alta) spring.
Old Mar 11, 2017 | 11:49 AM
  #35
Kirk Le's Avatar
Kirk Le
Does anyone know if the GFB DV+ is compatible with the new 11658636606 design? Would it be worth installing the GFB DV+ onto the newer diverter valve?
Old May 21, 2018 | 07:18 PM
  #36
blue al's Avatar
blue al
Is this latest design back compatible with the n14 engine,
as I've only see a listing on real oem for n18 cars ?
Old May 22, 2018 | 05:08 AM
  #37
All n14 and N18.
Old May 23, 2018 | 07:10 AM
  #38
cornjuice's Avatar
cornjuice
GFB for the N14 is a solid product (assuming you didnt get a knockoff on ebay). Far superior over the OEM design.. the GFB is not capable of mechanical failure.. its a solid piston design.
Super simple
easy install
bulletproof
Old Sep 4, 2019 | 08:50 AM
  #39
tcyracing's Avatar
tcyracing
[font][font]¡¡Hola!! [/font][/font]
[font][font]GFB n14 se puede utilizar en un MINI N18??? [/font][/font]
[font][font]gracias[/font][/font]
Old Aug 15, 2022 | 09:05 AM
  #40
We just found O-ring that fits as an upgrade also. Or replacement.
This works for that main yellow/range o ring:
https://www.ecstuning.com/b-bremmen-.../1295n464~brp/
Old Jul 9, 2024 | 01:32 AM
  #41
Telecine's Avatar
Telecine
Has anyone installed this new design in a Mini with an N14 motor?
Old Jul 10, 2024 | 08:27 PM
  #42
Telecine's Avatar
Telecine
Beuller?
Old Jul 11, 2024 | 05:20 AM
  #43
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What are you asking? This thread is mostly N14 users. This diverter valve will work just fine on any 2nd gen motor.
Old Jul 11, 2024 | 02:38 PM
  #44
Telecine's Avatar
Telecine
Thanks for the reply.
50% of online retailers say it isn't the correct part and 50% say it is. RealOEM says it isn't. I wanted to hear from people who have actually installed it that it works on an N14.
no1stunner
May 3, 2019 07:57 AM
Agbullet25
Apr 25, 2016 08:19 AM
Grizld700
Aug 12, 2014 05:18 AM
PJay Hamzad
Nov 6, 2012 12:17 PM
Cosmic Purple
Sep 8, 2005 10:52 AM
