Drivetrain Car Stalls After Sprint Booster Install on MCSa
I purchased a used sprint booster for an automatic Mini on the classified forums. When installing, I made sure to wait five minutes after unlocking the doors before unplugging the wiring harness behind the accelerator pedal. I plugged both ends in and re-assembled everything. When I turned the car on it stalled almost immediately and all the lights went on like a christmas tree on dash - SES, EP, EPL, you name it.
I turned the car off and on a few more times, each time it did the same thing. Then I removed the sprint booster and the car returned to normal after one or two restarts.
Then I re-installed the sprint booster. The same thing happened. My question is has anyone experienced something like this and/or does anyone have any idea what could be causing the car to behave like this?
The unit has the black cable, so it sounds like I have the right one. Is it possible the connection wasn't the greatest? I noticed the light on the selector was not on and was not coming on when pressed...
I bet one the codes stored is probably a throttle pedal malfunction....I think you are correct in not having a solid connection.
Check the pins from the front for straightness, try to reconnect.
If still an issue maybe a wire in the harness or a metal bushing contact in the connector has pulled out from the back, which will be hard to see since they are encased in the black shrink wrapping....
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
fm.illuminatus
Aug 10, 2015 12:15 AM
bctf1
Aug 6, 2015 12:55 PM
