Drivetrain Cracked Driving Light
Old Apr 7, 2004 | 06:19 AM
ScooterMan's Avatar
ScooterMan
The glass on one of my MINI driving lights is cracked. Anyone had this fixed that can tell me what I'm in for?
Old Apr 7, 2004 | 09:27 AM
Moorlockx's Avatar
Moorlockx
If I remember right, MINI doesn't sell the lens by itself. I think you're looking at a whole new light. Dependent on the cost you may want to look into a pair of aftermarket lights.
Old Apr 7, 2004 | 09:31 AM
dave's Avatar
dave
pug poo picker-upper
MINI also doesn't sell the glass for the fog lights or the clear plastic for the turn signal/park lights. For both of those lights, if you crack the glass/plastic (I've done both), you need to purchase a whole new assembly.
Old Apr 7, 2004 | 09:38 AM
TiMINITim's Avatar
TiMINITim
Does anyone know of a How-to for the assembly replacement? Mine is cracked :smile: .....but I might as well prepare for the inevitable.
Thanks!
Old Apr 7, 2004 | 10:38 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Replacing the OEM MINI driving light assembly is very easy, you dont even have to open the bonnet.
- Remove the phillips screw at the 6 o'clock position on the lamp bezel
- Pull the bezel outwards from the bottom, unhooking the edge at the top
- Disconnect the wires at the bulb lead and the reflector (if just replacing the bulb, just disconnect the bulb lead and remove the screw holding the bulb in place, then reverse the preceeding to reassemble)
- Push the wiring down through the mounting post, then remove the large mounting nut and remove the assembly
- Reverse order to reassemble
That's it! If you are replacing the entire assembly with an aftermarket lamp, you will have to splice the new lamp's wires to the existing harness wiring, most likely removing and discarding the original terminals. A hint there is to leave an inch of wiring remaining on the terminals if you ever want to reinstall the OEM style driving lights. This will give you something to splice to and still keep all the connections hidden inside the lamp assembly.
Those with OEM lights should be prepared to see the rust buildup inside the housings.
_________________
"Earl Grey" - '03 MCS, DS over DS, 17" R85s, NAV, DSC (often turned off!), Packs #1 and #3, Rally lights, etc, etc. Perf Mods by the boatload, on the way! Fulton, MD. FRS 7-21
Let's Get Small!
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
