Injectors are selected by the engine designer based on several factors, such as pressure capability, spray pattern, interaction with the ECU, etc. Installing injectors designed for a different car is like swapping out your OEM carburetor with another one that's completely untuned for the engine. Your best bet is to see about acquiring a set of 380cc JCW injectors used.
