Drivetrain type s intake system swap?
Old Mar 23, 2004 | 07:58 PM
Jonauto's Avatar
Jonauto
will the type s intake manifold and throttle body work on the cooper?
Old Mar 23, 2004 | 08:09 PM
Ryephile's Avatar
Ryephile
you mean the Cooper S intake manifold and TB?
Does the ETK/TIS say they're the same part numbers? I'm not positive.
Old Mar 23, 2004 | 08:23 PM
Jonauto's Avatar
Jonauto
no, the manifold is totaly different.... its metal and the cooper one is plastic and fiberglass.... i just wanna know if they will work on the cooper, and is the type S TB bigger than the cooper?
Old Mar 23, 2004 | 08:41 PM
Ryephile's Avatar
Ryephile
well, it might work, but not well. The intake runners on the MCS intake manifold are way too short for proper naturally aspirated tuning.
NOT "type S" - that's JDM lingo
Say: "Cooper S" - that's MINI lingo
Old Mar 23, 2004 | 09:40 PM
number_twelve's Avatar
number_twelve
You should also consider that the Cooper's plastic intake will have smoother surfaces for the runners than the S's metal runners, which usually feel like sand paper. I'd recommend finding a larger TB or boring out your stock TB.
I remember some folks were talking about this same issue on a different car (Neon) and most people recommended the same thing, saying the plastic manifold allows smoother air flow and to keep it.
Old Mar 23, 2004 | 10:28 PM
Mini_Street_Racer's Avatar
Mini_Street_Racer
unless of course you're planning to drill them for direct post nitrous then you'll have to switch to the metal cooper s intake
Old Mar 24, 2004 | 03:42 AM
jlm's Avatar
jlm
I fall you want to do is use the S throttle body, at the least, you would need an adapter plate, as the bolt pattern is larger for the S.
Old Mar 24, 2004 | 02:08 PM
Jonauto's Avatar
Jonauto
This is for the project Crispy Mini... im thinking that i will want to turbo it eventualy and i just cant see how a plastic intake mani will do well under pressure...
Old Mar 24, 2004 | 02:18 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Jon, your site is very entertaining.
Old Mar 24, 2004 | 03:21 PM
jlm's Avatar
jlm
jon, if you are looking for a few isolated parts, I might have the following, all from an S:
Throttle body
Intake manifold
Fuel rail
Fuel injectors
Ignition pack
Sparkplug wires
Valve cover
Old Mar 24, 2004 | 03:37 PM
Jonauto's Avatar
Jonauto
>>Throttle body
>>Intake manifold
>>Fuel rail
>>Fuel injectors
>>Ignition pack
>>Sparkplug wires
>>Valve cover
PM sent
Old Mar 24, 2004 | 05:45 PM
ABTsportsline's Avatar
ABTsportsline
love the site too! you are a pretty deft mechanic for someone of your age and experience. good luck with that rebuild!
god bless ebay, eh?
keep us posted on the progress.
Cheers
-ABT-
ebowling
90
Aug 4, 2019 09:15 AM
HaveATank
Aug 24, 2015 10:26 AM
The_Kid
Aug 16, 2015 11:13 AM
