Drivetrain having issues with jan/revolution mini
Old May 10, 2012 | 02:31 PM
  #26
davisflyer's Avatar
davisflyer
Originally Posted by m3sparky
thanks for the inputs guys, im feeeling alot better now being able to drive my mini around town. i just need to get rid off these runflats now
OK, sooo now that you seem to have your tune sorted out, are you happy with the results??
Old May 10, 2012 | 06:46 PM
  #27
automan21's Avatar
automan21
Oh man.....I just contacted jan for a tune on my 2011. This thread has me scared now:(
Old May 10, 2012 | 07:38 PM
  #28
11mcsaz's Avatar
11mcsaz
I hear you . . . . This is the kind of stuff that has me leaning toward either NM Engineering or Renntech.
I figured I would see how you fared with the RMW tune before deciding.
Old May 10, 2012 | 07:43 PM
  #29
automan21's Avatar
automan21
Lol I don't Wana be a guinea pig. Well who ever is within my budget I will go for first.
Old May 11, 2012 | 02:53 AM
  #30
HRM's Avatar
HRM
I was surprised about this issue since I know big bucks were spent on a jig to hold everything in place while working on the ECU. I can't say for sure, but perhaps it was careless re-assembly since while in the jig things should be very secure.
Some things you only do once, and this may be in that category. (I would hope) Whatever was done, would appear to be easy to avoid in the future.
Old May 11, 2012 | 01:17 PM
  #31
m3sparky's Avatar
m3sparky
theres still a couple problems im having , im getting a code thrown bank 1 fuel system to rich, and i have rough idle it jumps 200-300 rpm when idling .
im also noticing every time i wot it im having different boost levels , which is odd i would think that at a certain rpm i would get the max psi and it would stay there until i let go off the throttle. could it be possible i need a aftermarket blow off valve? because when im at wot the blow off valve seems to go off when im at wot . sorry for any noob questions im pretty new to mini.
Old May 11, 2012 | 01:24 PM
  #32
m3sparky's Avatar
m3sparky
im comapring the tune to the 335i ive had before i tuned it myself and when the boost kicks in at wot it would be at max psi until redline or until i let go off the gas.
Old May 11, 2012 | 02:08 PM
  #33
ThumperMCS's Avatar
ThumperMCS
Boost levels are usually not consistant on the R56...boost is dictated off of load targets rather than an actual boost target. Load will fluctuate based on several factors, thus you get different boost pretty much every time you go WOT. However, it should still always fall within a certain range.
Boost will drop off on the K03 because its tiny...it has almost no lag, and will reach full boost very quickly, but will not hold full boost till the redline like you want.
Old May 12, 2012 | 05:44 PM
  #34
automan21's Avatar
automan21
Gotta find out how much jans guna charge for the tune.
Old May 13, 2012 | 12:45 AM
  #35
Porthos's Avatar
Porthos
$500 for straight tune and I think $200 more for his tool with it.
Old May 13, 2012 | 05:57 AM
  #36
11mcsaz's Avatar
11mcsaz
I believe a RMW tune runs $600.
Old May 13, 2012 | 09:01 PM
  #37
killerfox's Avatar
killerfox
Straight from his website $500 for tune and $369 for flash tool.
Old May 13, 2012 | 09:39 PM
  #38
el chupacabra's Avatar
el chupacabra
Anyone have Jan's email address would be really appreciated thanks
Old May 14, 2012 | 04:56 AM
  #39
killerfox's Avatar
killerfox
Jbrueg@***.net or Jan@revolutionmotorworks.com
Old May 14, 2012 | 05:32 AM
  #40
MINIutia's Avatar
MINIutia
I'll sell you my flash tool I purchased from Jan for $50. It will cost another $100 to re-set it to work on another car. (sold)
Old May 14, 2012 | 08:28 AM
  #41
el chupacabra
Originally Posted by killerfox
Old May 16, 2012 | 09:33 AM
  #42
m3sparky's Avatar
m3sparky
what is the boost level after jans tune? the most consistent i have is 16.5psi. he also didnt eliminate the cel light from the catless downpipe , is there any other way to get rid off it?
Old May 16, 2012 | 02:46 PM
  #43
automan21's Avatar
automan21
+1 on the boost and cel light from the catless.
Old May 18, 2012 | 04:03 PM
  #44
gama's Avatar
gama
I wasnt about to purchase the RMW on my 2011 until I saw this post. Going with RENNtech tune.
Old May 18, 2012 | 07:33 PM
  #45
11mcsaz's Avatar
11mcsaz
"was" maybe?
I am fairly confident that all of the tuners are able to tune to disregard the catless/high flow downpipe CEL trigger. Why the OP did not receive this component of the tune is peculiar - after all Jan rode in the car with him.
Old May 25, 2012 | 04:13 PM
  #46
m3sparky's Avatar
m3sparky
i gave up on jan to try and do anything else with my car, ive wrote him about the partial refund he told me he would give back, and ive even asked that i dont need the partial refund if i can come by his shop when i will be in the area this summer to get rid off the cel light and double check that my tune is correct and got zero replies.
09R56
Nov 16, 2022 10:49 AM
Svejk
Feb 24, 2019 12:18 PM
arf88
May 31, 2016 03:07 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
tippin
Aug 5, 2015 08:43 AM
