Drivetrain 2003 MCS Engine Swap ???
Old Mar 26, 2012 | 12:27 PM
tgmedin's Avatar
tgmedin
What issues am I going to run into putting a 2005 MCS engine into a 2003 MCS?? I am having some issues with the 2003engine and I have a low mileage 2005 lump to install. Is it pretty much plug and play or are there things to look for.
Do I need anything specific?? I would assume the ECUs need swapped ?
ThAnks
Tom in pa
Old Mar 26, 2012 | 07:11 PM
kris kross's Avatar
kris kross
Everything is pretty much plug and play. Just be sure to change gaskets and other items that need replacement. You will need an engine hoist obviously, an engine leveler makes it easier to position the engine in and out. Everything else is pretty much hand tools. No ecu swap. The bentley manual does wonders. Have fun!
Old Mar 26, 2012 | 07:47 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You just reuse all your accessories and even wiring. You can't really take the ECU from the 05, your 03 will work fine. They are the same engine.
I would suggest a new clutch, crank pulley, thermostat, and gaskets.
bobbiemartin
Jan 20, 2016 05:28 PM
alistaircookie
Oct 8, 2015 10:52 AM
PrimePower
Aug 16, 2015 06:29 PM
PrimePower
Aug 11, 2015 12:51 PM
joelcseymour
Aug 7, 2015 12:43 PM
