Drivetrain Should i transplant a jcw into my mcs?
Old Mar 13, 2012 | 09:32 PM
  #26
miles_miles7's Avatar
miles_miles7
random pics
random pics
Old Mar 13, 2012 | 09:38 PM
  #27
miles_miles7
random pics
coming home after a long period of being stored
bottom end inspection
top end inspection
Attached Thumbnails Should i transplant a jcw into my mcs?-20120225_160216.jpg   Should i transplant a jcw into my mcs?-20120226_135254.jpg   Should i transplant a jcw into my mcs?-20120226_145817.jpg
Old Mar 13, 2012 | 09:43 PM
  #28
miles_miles7
random pics
degreasing
painted block
schrick getting transplanted
Attached Thumbnails Should i transplant a jcw into my mcs?-20120226_154946.jpg   Should i transplant a jcw into my mcs?-20120227_173017.jpg   Should i transplant a jcw into my mcs?-20120226_145802.jpg
Old Mar 13, 2012 | 09:49 PM
  #29
miles_miles7
random pics
goodbye oem camshaft
hello schrick
performed compression leakdown test (excellent result considering engine was cold) note my listening tool, its my CPAP machine hose.
Attached Thumbnails Should i transplant a jcw into my mcs?-20120228_192700.jpg   Should i transplant a jcw into my mcs?-20120228_201617.jpg   Should i transplant a jcw into my mcs?-20120227_200637.jpg
Old Mar 13, 2012 | 10:02 PM
  #30
miles_miles7
random pics
degreasing the tranny
shitty day in sunny san diego
ah the clean tranny
Attached Thumbnails Should i transplant a jcw into my mcs?-20120227_174303.jpg   Should i transplant a jcw into my mcs?-20120227_174327.jpg   Should i transplant a jcw into my mcs?-20120227_181612.jpg
Old Mar 13, 2012 | 10:10 PM
  #31
miles_miles7
random pics
oem open diff
valve cover getting prep for wrinkle black or red coating
obx lsd (at the machine shop for modification, yes its getting modified) note the metal shaving left from manufacturing). ordered the stronger washers and bolts. cleaned up the edges already. bearings are in (made in USA), bought the NAPA (made in china) bearings but returned them.
Attached Thumbnails Should i transplant a jcw into my mcs?-20120227_173033.jpg   Should i transplant a jcw into my mcs?-20120226_145835.jpg   Should i transplant a jcw into my mcs?-20120308_153144.jpg
Old Mar 13, 2012 | 10:17 PM
  #32
miles_miles7
parts
massive A2W radiator
gutted the oem water pump (going electric pump) for re-use. i tried to be nice to it but it was stubborn and lost the battle to the hydraulic press.
oh yeah just a few loose metal chunks from the obx
Attached Thumbnails Should i transplant a jcw into my mcs?-20120220_151447.jpg   Should i transplant a jcw into my mcs?-20120307_154039.jpg   Should i transplant a jcw into my mcs?-20120308_153335.jpg
Old Mar 13, 2012 | 10:26 PM
  #33
miles_miles7
more to come
more will be uploaded, wife is complaining already so she wants to be pat down . as i mentioned earlier my obx is getting modify at the machine shop, more to come on that. im still debating which clutch kit im going to use. i was driving around and found a local shop that re-works oem clutch/flywheel and can manufacture 3/6 paddle disc . right now the car is being fitted with the AW2 radiator and associated parts. the simple baffles strips for the oil pan needs to be welded on. pretty much the 03 MCS is still being driven around tilll the JCW engine and 05 tranny comes together again. more to follow......
Old Mar 16, 2012 | 07:07 PM
  #34
miles_miles7
Update on the obx lsd modification
Before i did this gutsy move on my LSD i did some reading on honda forums about thier experience on OBX LSD. Some are tracking thousands of miles without issues and there are those people that had problems with it. I know the consequence of voiding the warranty from my seller if something would happen directly or indirectly of this modification. oh well.....
to sum up the things i did before the modification i did the following.
- cleaned up the sharp edges with my dremel tool.
- i had it plastic beaded ( a guy here i believe did a glass bead and turned out beautiful)
- ordered the stronger washers and bolts.
Old Mar 16, 2012 | 07:22 PM
  #35
miles_miles7
OBX oil flow
- 1st pic, this is how the obx going to be installed in the tranny and that arrow is the point of rotation when the vehicle is going fwd.
- 2nd pic, the oil will enter in that hole (see the coil? we'll call that coil as lower coil because when the housing is standing up its at the bottom) and because of how the helical coil spins inside the housing the oil it will exit to the right (marked exit). With that said the lower helical gets all the positive flow of oil coming in. the upper coil may only get partial oil and or low flow of oil because as oil enters it exits right away.
- 3rd pic, here is the modification done to the LSD, added oil passage way. As the LSD housing spins it scoops the oil in and showers the upper coil. Because of how the upper coils spins inside it brings the oil up to the driver side drive gear.
Attached Thumbnails Should i transplant a jcw into my mcs?-20120316_182309.jpg   Should i transplant a jcw into my mcs?-20120316_182354.jpg   Should i transplant a jcw into my mcs?-20120316_182535.jpg
Old Mar 16, 2012 | 07:40 PM
  #36
miles_miles7
OBX mod
- 1st pic, oil enters
- 2nd pic, helical coil rotation, as oil enters the coil will bring it in to the left lubricating the driver side axle gear
- 3rd pic, oil exit point
Attached Thumbnails Should i transplant a jcw into my mcs?-20120316_182456.jpg   Should i transplant a jcw into my mcs?-20120316_182929.jpg   Should i transplant a jcw into my mcs?-20120316_183122.jpg
Old Mar 16, 2012 | 07:55 PM
  #37
miles_miles7
OBX mod
- 1st pic, other half of the housing. noticed the cut? that's the entrance point.
- 2nd pic, here is how it will look.
- 3rd pic, just to show the upper and lower helical coils (before the mod pic).
Attached Thumbnails Should i transplant a jcw into my mcs?-20120316_182620.jpg   Should i transplant a jcw into my mcs?-20120316_182755.jpg   Should i transplant a jcw into my mcs?-lsd2.jpg
Old Mar 16, 2012 | 08:16 PM
  #38
miles_miles7
Theory
Why did i do this? because i can .
Like i said the honda guys racked up some thousand miles w/out the issues. Some did the clean up and changed the factory washers, i'm doing that too.
On the net i saw some chewed up driver side axle gear and cooked up oil spots. My theory is that the upper helical coils don't get much positive flow of oil compared to the lower ones which drove me to do this. The issue could just be material finish from the factory but at least i know the upper coil and driver side axle gear will get MORE flowing oil thru them.
Ok guys shoot my post with bullet holes, make comments and criticism but be nice.
Some guys will be eating popcorn like this guy and just keeping an eye on this project.
Tomorrow the LSD willl be put together and bearings will be mounted.
MORE TO COME AS THINGS PROGRESS.
Old Mar 17, 2012 | 02:37 PM
  #39
miles_miles7
Ummmmm?
800 plus views and no comments or suggestions lately?
I guess everybody are and some are and more ?
Old Mar 22, 2012 | 01:32 PM
  #40
miles_miles7
Quick update
Dear Diary not a whole lot done since i last posted.
- Still deciding which clutch kit I'm going to install.
- LSD is assembled, had to do double check with the driver side shaft locking C CLIP, looks like i have to either get the diver side drive gear or the drive shaft machined for the C CLIP to lock in place. Once my 03 shafts are out i will install them on the lsd to make sure the driver side locks in and won't get stuck permanently. With that said i won't close the 05 tranny just yet till everything is good with the lsd and shafts
- painted the valve cover with red wrinkle (more like orange) and man its pretty.
- welded the baffles on the oil pan.
Pretty much I'm ready to tear apart the 03 MCS and yank the engine and tranny in the next few days. Gathering all the parts and tools i need in this one man job, Wife doesn't want to get her finger nails dirty
Old Mar 22, 2012 | 11:49 PM
  #41
miles_miles7
Prepping 05 tranny
1st pic, re-installed useable bushing and used hi-temp silicone to isolate little movement. Make sure clean silicone around it, no more movement with silicone.
2nd pic, cleaned, measured some tranny parts and run bolts thru tap and die to clean threads. Note the 3 piece bearing
3rd pic, this was yesterday during assembly of the LSD.
Attached Thumbnails Should i transplant a jcw into my mcs?-20120322_212129.jpg   Should i transplant a jcw into my mcs?-20120322_210902.jpg   Should i transplant a jcw into my mcs?-20120321_135048.jpg
Old Mar 22, 2012 | 11:54 PM
  #42
miles_miles7
Not so red valve cover
1st pic, its the only red wrinkled paint i can get anywhere but each day i look at it the more i'm lovin it. This thing is prettier than ENRIQUE IGLESIA .
2nd pic, up close and note the detail of the wrinkled finish. under the sun its noticeable and the color is redier (is that right?).
Attached Thumbnails Should i transplant a jcw into my mcs?-20120322_220534.jpg   Should i transplant a jcw into my mcs?-20120322_220550.jpg
Old Mar 23, 2012 | 10:00 AM
  #43
kazlot's Avatar
kazlot
Originally Posted by miles_miles7
1st pic, its the only red wrinkle paint i can get anywhere but each day i look at it the more i'm lovin it. This thing is prettier than ENRIQUE IGLESIA .
No, the spelling is redder.
But I must concur with your opinion, the look of the finished product is outstanding!
Old Mar 23, 2012 | 02:01 PM
  #44
miles_miles7
thanks Kazlot for the correction. i guess you are not a popcorn guy that likes to seat back and actually likes to make comment(s). a lot of members here have tight lips
Old Mar 30, 2012 | 04:38 PM
  #45
miles_miles7
Notes for future reference
MINI COOPER S FIRING SEQUENCE: 1342
WHEN CYL #1 IS TDC:
#2 int open, #3 exh open, #2&3 pistons are at the bottom
WHEN CYL #3 IS TDC:
#4 int open, #1 exh open, #1&4 pistons are at the bottom
WHEN CYL #4 IS TDC:
#3 int open, #2 exh open, #2&3 pistons are at the bottom
WHEN CYL #2 IS TDC:
#1 int open, #4 exh open, #1&4 pistons are at the bottom
At 53k miles the JCW engine had 20, 23, 23, 19 psi (green zone) during compression leak down test considering its cold engine. During pressurization no evident of hissing noise coming from exhaust/intake ports, and coolant openings. Adjacent cylinder didn't show any air coming from the cylinder being tested. The hissing noise came only from the oil dip which tells me compressed air escapes thru the piston rings. Any engine will have some degree of air leaking thru the rings.
JCW cylinder int/exh ports opening measurements
INTAKE - 41.5MMX20MM
EXHAUST - 34.5MMX24MM
OEM cylinder int/exh ports opening measurements
EXHAUST - 33.5MMX20MM
FELPRO INTAKE/EXHAUST GASKETS MEASUREMENT
INTAKE - WHEN I GET TO IT
EXHAUST - 41MMX31MM
COSWORTH CYLINDER INT/EXH PORTS OPENING MEASUREMENTS
INTAKE - 43.5MMX23.5MM
EXHAUST - 39MMX23MM
OEM INTAKE RUNNER PORTS MEASUREMENTS
40MMX21MM OEM NEEDS SOME WIDENING
OBX HEADER PORTS MEASUREMENT
EXHAUST - 39.5MMX25.5MM
This note will be constantly updated.
Old Apr 4, 2012 | 08:06 AM
  #46
dinanminicooper's Avatar
dinanminicooper
I just installed an OS Giken LSD and ACT Streetlite flywheel and new clutch. Work amazingly well, now the car is 2 wheel drive on the track!
Old Apr 5, 2012 | 11:30 AM
  #47
Carmichael's Avatar
Carmichael
Interesting read. I just had my TOB grenade on me, so I have a clutch job to do. My OBX LSD just came in to my parents' place as well (can't work on cars at my place Gotta love apartments in Chicago). I ordered the belleville springs and bolts, too (from RBryant), so I'll be doing that this weekend.
Curious about the oil passages you machined into the casing. What did you tell your machinist to do? I'm sans-auto for a month, so I might as well do everything I can do the car to make sure it doesn't just die on me again. Thanks in advance.
By the way, I've noticed that although there are people on this forum who are very helpful, most tend to keep their hands clean by letting a mechanic do their work, which is why technical build-up/tear-down threads like this don't get much traffic.
Subscribed for more info!
Old Apr 5, 2012 | 12:06 PM
  #48
CrazyIvan's Avatar
CrazyIvan
what red wrinkle paint is that?
Old Apr 5, 2012 | 12:12 PM
  #49
Miniman s's Avatar
Miniman s
Has anyone done a comparison between the OBX and OS Giken LSD?
Old Apr 5, 2012 | 01:33 PM
  #50
Act_04's Avatar
Act_04
Thanks for posting. The red looks fantastic. I believe the proper grammar is "more red".
