Drivetrain ignition coils and spark plugs help
Old Dec 13, 2011 | 06:42 PM
FUBSZ's Avatar
FUBSZ
hey guys i recently got silver spark plugs for the apparent misfire that is happening to the car that has been going on. but it seems i still need to get coils to go with it . the OEM gets 70$x4 but the only after market i found is this http://new.minimania.com/web/Item/G2.../InvDetail.cfm
its 600$ :S seems alot . do i need to change the coils or is it fine with OEM ?
Old Dec 13, 2011 | 07:22 PM
bluefox280's Avatar
bluefox280
The OEM's are simply hard to beat; why spend why more on an electrical component then that of the affordable (and I do mean it) OEM ones?
Plus, I'd be diagnosis an electrical misfire with a multimeter and data-log testing before dropping $600 on non-refundable parts.
How are you determining that your current coils are shot?
- Erik
Old Dec 13, 2011 | 08:22 PM
FUBSZ's Avatar
FUBSZ
well i sent it over to my trusty mechanic for installation on spark plugs and he told me the misfire was coming from the coil not the spark plugs.
Old Dec 13, 2011 | 09:28 PM
bluefox280's Avatar
bluefox280
If true, you can swap the coil to as different cylinder.
If the misfire moves to the swapped cylinder, you know the ignition coil is faulty.
Go with the OEM units; they're hard to beat.
- Erik
Old Dec 14, 2011 | 03:27 AM
FUBSZ's Avatar
FUBSZ
Great idea !! but just in case it does turn out that the coil is faulty , will OEM be fine when the car is fully modded ? with silver plugs ?
Old Dec 14, 2011 | 06:35 AM
ThePenl's Avatar
ThePenl
Beware that some of us used the silver plugs and had problems with misfires and rough idle as well.
In my case the plug itself induced the misfires and not the coil. Returned to the stock NGK Platinum and had no problem ever since.
Where did you get your plugs from?
Old Dec 14, 2011 | 06:36 AM
Porthos's Avatar
Porthos
If you can get those get them. Those are legit.
Those these are not on the MINI they show that they will provide better ignition over stock. So it boils down to if you want to spend an extra $320
over what you would spend for stock.
http://dsportmag.com/browse/tech/qui...-plasma-direct
http://www.importtuner.com/powerpage...s/viewall.html
rob76turbo
Sep 15, 2015 10:11 AM
JMF1975
Sep 11, 2015 03:29 PM
kjd186
Sep 9, 2015 10:02 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
