Drivetrain Need a rebuilt engine for 2005 mini cooper s. Can I use a 2011 engine in a 2005 frame
Old Nov 8, 2011 | 08:47 PM
rbennett's Avatar
rbennett
Can I use a 2011 engine in a 2005 frame or do you have to change transmission or anything?
Anyone know a good place to buy and have a rebuilt engine installed in/near San Jose CA?
Thank you
Old Nov 8, 2011 | 09:18 PM
Eric_Rowland's Avatar
Eric_Rowland
I'm no expert, but you'd probably have to swap out the ECU at a minimum. Not sure about the engine mounting points. Cars these days are less swap ready given all the electronics.
Old Nov 8, 2011 | 09:37 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Nope cant use the aluminum "Prince" engine ('07+) in a first generation car. The only engine that you can stuff in an '05 would be the TriTec engine '02-'06+'07-'08 0n convertibles.
All the Tritec's are not built the same, the Cooper (NO S/C) has a higher compression ratio, and weaker internal parts. The Cooper S Supercharged engine has lower compression and a pretty strong bottom end. The JCW packaged engines for both models used a factory ported head on their respective engine.
Old Nov 8, 2011 | 09:58 PM
rbennett's Avatar
rbennett
Where is the cheapest place I can get a Jcw engine for my 2005 mini cooper supercharged? What engine do I go with? The same R53 but rebuilt by JCW?
Where should I have it installed in San Jose Ca? South Bay
Old Nov 8, 2011 | 11:00 PM
BlwnAway's Avatar
BlwnAway
Way Motorworks
Old Nov 8, 2011 | 11:04 PM
rbennett's Avatar
rbennett
I have a mini cooper R53 engine in my 2005 mini cooper s hard top. I can't put a R56 in it even?
I found a shop in Los Gatos CA called BR Racing that looks good to do the engine install. I need to find an engine now, or rely on them to find it for me.
Old Nov 9, 2011 | 05:00 AM
buzzsaw's Avatar
buzzsaw
Originally Posted by BlwnAway
Way Motorworks
or Justin at AutoXcooper
Old Nov 9, 2011 | 07:07 AM
nodoze's Avatar
nodoze
What about a non-mini engine swap? I can't imagine it's literally impossible to put a B16a in a Mini, it might be a pain in the *** but there must be a way to make it work no?
Old Nov 9, 2011 | 08:23 AM
DICKS GARAGE R53
It might not be totally impossible but you are going to spend more trying to make it work than the car is worth. The electronics in theese cars are not easy to work with, plus all the custom parts that will need to be made.
Best place to get a new remanufactured engine that I have found is WAY MOTORWORKS. He has them going at a good price for a complete new engine.
Old Nov 9, 2011 | 09:11 AM
BlwnAway's Avatar
BlwnAway
http://www.waymotorworks.com/john-co...53-engine.html
$4900.00
Old Nov 9, 2011 | 10:50 AM
DICKS GARAGE R53
Thanks Mark I was going to do that but MW3 got in the way again.
Old Nov 9, 2011 | 08:11 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
An R56 engine won't fit an R53.
We have new engines, and we also have a few low mileage used engines from wrecked MINI's we're parting out.
Old Nov 10, 2011 | 08:15 AM
OldGameFreaK's Avatar
OldGameFreaK
Anything CAN be done!! It just depends on how deep your pockets are:
http://www.youtube.com/watch?NR=1&v=CDBFAt3uqrc
Old Nov 10, 2011 | 11:31 PM
UKSUV's Avatar
UKSUV
If you know someone at the dealer....dealer cost for a remaned engine is roughly $3k. Just throwing that out there...
Old Jul 28, 2019 | 08:34 PM
cramaekers's Avatar
cramaekers
Delete me
Old Aug 12, 2019 | 12:48 PM
R534life's Avatar
R534life
For the amount of work to make a prince engine work in a 05 you could swap just about any engine in the world in. So why would you chose the prince engine? I'd think for less then the price of a MSRP R53 JCW engine you could get a K series in it making a fair bit more power. Being an aluminum block you might actually cut some weight out of the front end. K24A2's are selling for like $500-800 on the used market. But you'd need a full swap kit and they sell for more.
iggi
18
Feb 9, 2026 01:00 AM
SosoMINI
Nov 22, 2015 03:17 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
joelcseymour
Aug 7, 2015 12:43 PM
M7Speed
Aug 6, 2015 01:48 PM
