Drivetrain Where to grab boost reading on 2011+ N18?
Resurrected, this thread is!
Yes - I used a BSH boost tap adapter at the port on the intake manifold shown in the top right of the picture.
Been running strong ever since (boost and vac)!
is this the one i need? http://www.waymotorworks.com/bsh-boost-tap-r56.html
i can't see where this goes on my car, do i need to remove the airbox to see it?
thanks!
thanks!
This is the SKU of the one I purchased at OutMotoring:
20201102 BSH Direct Dual Boost Tap
Yes, you will need to remove the airbox and place this in between the tube shown at the base of the intake manifold. It goes right in, then is secured with the locking arm. Then, connect the hose as usual and you're all set.
For the life of me I can't remember which of those it is (hose or cap) but you will figure it out really quickly with the diameter of the boost tap - they're different sizes, and only one is large enough. I think it was the capped one.
To remove, squeeze the sides of the plastic ring to release the two middle tabs and pull outward.
Colt45Magnus
Aug 27, 2024 05:03 AM
Sep 2, 2015 01:10 PM
Sep 2, 2015 01:08 PM
