Drivetrain Aggressive exhaust
Old Oct 28, 2011 | 04:46 AM
  #101
SooperCuperErik's Avatar
SooperCuperErik
What do you want to know? Its pretty straightforward, you can either do a manual or electronic, or boost controlled. Easiest is obviously manual, which has 3 butterfly nuts and a block off plate that is on a Y pipe essentially. The Y pipe gets welded where you want in line with your current exhaust, likely after the DP or on the DP(though not much room here unless you're catless). Same goes for electronic, but instead of opening the nuts yourself you flip a switch, though these are known/can leak after a while, as the seals will get exhaust build up on them and cause gaps in the seal, or the motor gets weak and isn't able to apply enough torque to hold it closed.
I'm currently in the works of bringing my straight pipe back to the stock piping between the DP and the magnaflow muffler in the rear (the magnaflow box on stock piping will sound a bit sportier than stock, with 0 drone, plus i love how my 4" tips look), weld a cutout after the catless DP before the stock piping starts back up, and running a side exit exhaust for a catless dump.
Now all of you go and copy me and get it done before I do so you can claim being "the one"
Old Oct 28, 2011 | 12:26 PM
  #102
Achilles honor's Avatar
Achilles honor
You think this will throw any CELs if i do a cutout and my friend had the same problem with his cutout in his DP leaking. But its still worth it. its such a fun mod.
Old Oct 29, 2011 | 10:55 AM
  #103
Boosted_Mini's Avatar
Boosted_Mini
So what times did this kid run
Old Oct 29, 2011 | 12:22 PM
  #104
Achilles honor
Yeah we're are these videos of the muffler delete?!?
Old Oct 29, 2011 | 01:49 PM
  #105
ThePenl's Avatar
ThePenl
If you like aggressiveness then you should try deleting the resonator.
With a 100cpi DP, a JCW kit back box and a 63,5mm straight in between it has all the aggressiveness anyone needs.
It is louder without the resonator and the pops&burble are in another league!
I will try to post some videos for you to listen.
Old Oct 29, 2011 | 05:15 PM
  #106
Achilles honor
I've already removed y resonator I have a custom 3" magnaflow on from do back fright now
Old Nov 2, 2011 | 09:51 AM
  #107
SooperCuperErik
No, nothing is monitored post DP.
The only concern should be "too" free flowing with no backpressure. It can lean out the car and cause issues, but running on lamda should keep most of those issues away. Regarldless, thats why I plan on running cutout to a resonator, since leaving the DP sounds pretty gross imo, the bad raspy.
Old Nov 3, 2011 | 10:18 AM
  #108
ALTAPerformance's Avatar
ALTAPerformance
Lambo Exhaust on your MINI?
Old Nov 3, 2011 | 11:52 AM
  #109
Achilles honor
Lol that's awesome.. It's like a gas rc car lol.. Are y'all really selling those?
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
embiggenedmini
Oct 15, 2015 12:36 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
