Drivetrain DDMWorks R56 Race Intake System (RIS)
Old Oct 20, 2013 | 06:44 PM
  #51
nine5raptor's Avatar
nine5raptor
I'll check out afe. I was also looking at aem but need to check sizes tomorrow when its light out. Found this one.
Old Oct 20, 2013 | 06:50 PM
  #52
DTH2CHRM's Avatar
DTH2CHRM
AEM...another very good choice
Old Oct 20, 2013 | 07:28 PM
  #53
marvinclick's Avatar
marvinclick
Originally Posted by MiniWii
Yes, use the stock one instead of that soft tubing/ I've contacted DDM and was told they will look into it.. we'll see what happens..
Just remove the stock piping before you install the DDM intake and reinstall it after everything is in place and tightened down. It will fit with no issues.
Thanks, will try back.
Old Oct 21, 2013 | 06:35 AM
  #54
Tigger2011's Avatar
Tigger2011
Alliance Member
Originally Posted by DTH2CHRM
That's great. I really hope it holds up well. I liked everything about the DDM RIS, but I think they skimped out on the vacuum hose.
Agreed, the line provided leaves something to be desired. However it is possible to re-use the factory rigid line. The factory hose coupler can be rotated to attach to the vacuum pump fitting after it is rotated per the RIS installation instructions. You can also remold the rigid line by utilizing a heat gun. Took very little in the way of bending to get it to fit. Be careful applying heat and work a little at a time. Too much bending while heating the line will link it.
Old Oct 21, 2013 | 06:39 AM
  #55
nine5raptor
I'm real curious how you guys could rotate yours. The only way I could do that on a 2010 was to leave bolt out and the fitting partially unplugged and that won't work.
Old Oct 21, 2013 | 01:53 PM
  #56
Tigger2011's Avatar
Tigger2011
Alliance Member
Here's a few pics that might help.
Old Oct 21, 2013 | 02:10 PM
  #57
DTH2CHRM's Avatar
DTH2CHRM
I have an '09 and my engine is the same as yours. When I first rotated mine, I screwed the bolt back in...1. So I wouldn't lose it and 2. So that it would help keep everything from moving around too much.
I'm not really sure how else it could be rotated to make things 100% secure. I definitely had play in mine...it wasn't sturdy enough to ease my initial worry.
Old Oct 23, 2013 | 12:16 AM
  #58
marvinclick
i don't know you guys ever noticed the DDM manual said using the soft pipe need to 90 degree faced the passenger side, comparing to the stock hard pipe.
and after i did so, realized that cannot use the stock screw anymore, now the soft piple just simply attached to the hole... is it safe? really worried.
Old Oct 23, 2013 | 05:50 AM
  #59
6000pounds's Avatar
6000pounds
I said earlier in this thread I was going to sell mine and get a carbon fiber hood. After reading countless threads on fitment from different companies I'm going to opt for keeping my stock hood and just run a carbon fiber hood scoop. Sorry for the couple people that were interested in it through PM's and the like. The only CON I will say about this intake is that it's a pain in the *** to get the filter out and clean it.
Old Oct 23, 2013 | 06:52 AM
  #60
Tigger2011's Avatar
Tigger2011
Alliance Member
I only have one issue with the RIS intake. The scoop which acts as a great heat shield for your hood scoop will become heat soaked from the turbo in stop and go traffic. In heavy traffic I've seen IAT's climb 19 degrees above ambient even with a Forge FMIC. Have some 1/4" Dynaliner on order to install on the scoop and plan on wrapping the turbo hot side and DP with DEI Titanium wrap when I get my catless DP. That should solve that little issue.
W0TM8
Dec 19, 2019 07:50 AM
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
The_Kid
Aug 16, 2015 11:13 AM
Aug 12, 2015 01:24 PM
