Drivetrain Catalytic Converter Help pls!
Old Aug 25, 2011 | 11:03 PM
Silver253's Avatar
Silver253
My Cat came apart yesterday while on my way to work. It sounds like garbage. I have searched through many threads looking for a good Aftermarket cat finding no real solid answer. Ive read magnaflow makes a 65$ cat but i cant seem to find it.I took it in to a local shop and they wanted 600$ to replace the cat which i thought was extremely rediculous. I have sinced ordered a megan header with the test pipe for now.
I really would just like a link or part no. for a cheap cat that will work =D
Thanks for all your help
Old Aug 26, 2011 | 03:12 AM
veggivet's Avatar
veggivet
Cheap catalytic converter? No such thing. My Milltek set me back over a grand. $600 is about right for the low end stock replacements.
Old Aug 26, 2011 | 06:17 AM
BlwnAway's Avatar
BlwnAway
The stock CAT will probably give you the longest life, they seem to hold up to the heat best esp. with a header. Shame you already ordered the header, the V2 I just installes was $1150.00 CAT uncluded.
Old Aug 26, 2011 | 07:54 AM
2mD's Avatar
2mD
cheapest way would probably be to search for a used oem manifold...
Old Aug 26, 2011 | 09:04 AM
ACallahan's Avatar
ACallahan
I have an 05 manifold and cat. Low miles removed for aftermarket . Pm me with an offer and for pics.
Old Aug 26, 2011 | 09:35 AM
jhiggs26's Avatar
jhiggs26
I'm running this part # with my header. I custom cut it and welded on flanges to fit my header. Note my test pipe would not have mated up properly to my stock catback. The length and angles were incorrect.
http://www.amazon.com/Magnaflow-9103.../dp/B000COTIAM
Jeremy
Old Aug 26, 2011 | 09:41 AM
jhiggs26's Avatar
jhiggs26
Here's my thread from a couple years back on my header and cat install(similar/same to Meagan).
https://www.northamericanmotoring.co...rt-header.html
Jeremy
Old Aug 26, 2011 | 02:26 PM
Silver253's Avatar
Silver253
Thanks Jeremy that is exactly what i was looking for!
shorenetworks
Nov 4, 2019 06:18 PM
Sep 18, 2015 02:44 PM
Sep 14, 2015 12:48 PM
Sep 10, 2015 10:52 AM
Sep 4, 2015 12:20 PM
