Drivetrain MAF values - getting useful data
Old Aug 24, 2011 | 12:49 AM
jlevy's Avatar
jlevy
When logging MAF values with the Access Port, a unitless number is the resulting data. Alta says that dividing this number by 2 is close to the g/sec airflow, but did not really have a good answer. I've come up with a calibration value and was wondering of anyone else has done this so I can fine tune this number if needed. See below for the number and how I use it (MAF is plotted against pressure ratio on top of the compressor map using MS Excel)
MAF value/29 = pounds per minute air flow
The attached plot is for AP stage 1 tune (91 octane TPS map). Boost hits just below 21psi in this particular 3rd gear pull. The points are RPM from 2000 to 6000 in various increments.
-JL
edit:
The MAF data appears to be linear and matches to within 5-10% what my predictions show
Attached Thumbnails MAF values - getting useful data-stock-mcs-turbo-comp-map-with-data.jpg
Old Aug 26, 2011 | 08:26 PM
doug@frankenturbo's Avatar
doug@frankenturbo
Are your MAF numbers ranging anywhere between 400-600 at peak? If so, then the ecu is reporting Kg/hr. Divide this number by 0.27777 to get the g/sec figure.
MGBill1186
Oct 2, 2015 06:54 AM
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
The Rossness
Sep 17, 2015 03:06 PM
papawhiskey
Sep 14, 2015 05:47 PM
