Drivetrain R56 Upper radiator Hose Inner diameter size?
Old Jul 24, 2011 | 03:08 AM
mini4tide's Avatar
mini4tide
Does anyone know what the inside diameter of the upper hose is? I'm guessing 1.25", but could be wrong. Looking for a temp sender adapter thats not so expensive and need to know size. thanks
Old Jul 24, 2011 | 08:00 PM
mini4tide's Avatar
mini4tide
No one's done this? Anybody?
Old Jul 24, 2011 | 08:15 PM
bluefox280's Avatar
bluefox280
Versus taking the circumfrence of the pipe, converting to the diameter and subtracting twice the wall thickness?
- Erik
Old Aug 17, 2011 | 05:39 PM
koolburro's Avatar
koolburro
Did you ever figure out the inside diameter of the hose? I think I'm doing exactly what you were doing. Just got a Prosport Water Temp guage and now I'm looking to get their hose adapter to mount the sender.
Thanks!
Old Aug 17, 2011 | 05:49 PM
SooperCuperErik's Avatar
SooperCuperErik
As Erik said, you'd save yourself a lot of time by just measuring it yourself, take the circumference, subtract two times the wall thickness from the diameter. If ones willing to mount a sender unit, you should be able to do this.
To get a diameter from a circumference, pi * D = circumference, where pi = 3.1415, and D = diameter.
So for Diameter, its D = Circumference / 3.1415
Measure the diameter by taking a piece of string and wrapping it around the hose, mark it off with your finger, and unroll it straight onto a ruler to give you the length.
For the wall thickness, its the thickness of the rubber hose.
Alternatively, you can just run a ruler roughly across the center of the pipe, and round it to the nearest "known" ID value, but the circumference method may yield a more accurate result.
Old Dec 3, 2014 | 01:33 PM
MiniVelvet's Avatar
MiniVelvet
1.25 inch according to a part match found on Oreily's site.
http://m.oreillyauto.com/mt/www.oreillyauto.com/site/c/detail/GAT0/23483/01358.oap?year=2011&make=Mini&model=Cooper&vi=1501 047&ck=Search_coolant+hose_01358_1501047_2854&keyw ord=coolant+hose&pt=01358&ppt=C0331
Can anyone confirm that fitment is right with a 1.25' hose? I need to replace the two hoses that are connected by a metal coupler that was left behind after a recall. Thanks!
Kimolaoha
Dec 5, 2020 09:32 PM
tr3y003
Oct 22, 2015 10:48 AM
Mini'mon
Aug 16, 2015 04:15 PM
BernieCoop
12
Aug 12, 2015 07:45 AM
