Drivetrain CP Pistons/Scat Rods for the R56 - Sorta
Old Jul 20, 2011 | 06:31 AM
Boosted_Mini's Avatar
Boosted_Mini
So recently i have been looking for pistons and rods as I see ours tend to have some issues.
In doing so it has been very hard to find them, until I start searching the Peugeot 207.. which ideally has the exact same motor as the R56 MCS.
Has anyone tried to put CP pistons in our car that are made for the Peugeot?
Link:
http://eshop.kanteres.gr/en/virtuema...id=28&vmcchk=1
Or Scat Rods:
http://eshop.kanteres.gr/en/virtuema...category_id=28
Thoughts?
Old Jul 20, 2011 | 07:16 AM
2009R56JCW's Avatar
2009R56JCW
Pistons and rods will fit a pug or mini prince shortblock.
Old Jul 20, 2011 | 09:36 AM
tintman718's Avatar
tintman718
The rods you have listed look like they're for the previous generation Peugeots, but the pistons will work (R56 application is mentioned). That's some serious cash though, considering it only has 4 pistons. Has anyone ever heard of this company CP?
Old Jul 20, 2011 | 09:48 AM
czar's Avatar
czar
Link:
Or Scat Rods:
Thoughts?
It's pointless swapping your factory OEM pistons until you either have a piston failure/detonation issue, or you know the exact cause of your stock OEM piston failure in the first place!
Simply swapping to an aftermarket piston, will not cure whatever issue, you or anyone else has, you must find the cause first.
CP pistons, try this link below.
http://www.shop-cppistons.com/
Old Jul 20, 2011 | 09:51 AM
Mike@Tech Division's Avatar
Mike@Tech Division
If the CP's work then that's a decent option as long as the rings can be filled to a decent gap. Had problems with them over gapping from the start. IF some one does figure out they work for sure then I would get them state side. The exchange rate on the ones in the link would be killer.
The rods may be a little sketchy. Never been a fan of scat rods. Quality control is a little shaky.
Old Jul 20, 2011 | 09:59 AM
czar's Avatar
czar
Those CP pistons will NOT work with the stock OEM connecting rods, the stock connecting rods are trapezoidal and matched to the trapezoidal stock OEM pistons.
In order to utilise those CP pistons you will have to use them with those Scat connecting rods, or another flat square shouldered connecting rod, from another aftermarket company.
Old Jul 20, 2011 | 10:29 AM
Mike@Tech Division
Yeah I was wondering if that was the case. That's how we designed our stuff, but I wasn't sure if the pics in the link were the actual rods or just a generic image of scat rods.
Old Jul 20, 2011 | 04:03 PM
Raymazing's Avatar
Raymazing
Link:
Or Scat Rods:
Thoughts?
I posted these a couple months ago. They've seen some solid numbers on some of the EU cars. Needless to say Czar you're the man, the use of the scat rod or another with very similar specs is required. I don't recall anyone running these stateside but I've used each company separately on different projects. Its my understanding though that scat has improved dramatically over the last 10 years.
Old Aug 24, 2012 | 11:43 AM
solskjaer1999's Avatar
solskjaer1999
Raymazing,
I'm looking at trying to get about 280-290ish whp into my 2008 MCS. Will I be ok to keep the stock rods and piston heads without damaging or blowing my engine? If not, are they any options besides the connecting rods and pistons mentioned above?
Old Sep 17, 2012 | 01:00 PM
luis_villarruel's Avatar
luis_villarruel
What do you think about this rods??
http://www.etuners.gr/en/index.php?s=12&t=301
From etuners forum:
Originally Posted by Stelios
A lot of people have been asking about these rods.
Probably after reading the article about their similarity to stock THP rods, here: http://www.etuners.gr/en/index.php?s=12&t=301
Here is how you can make them fit.
First you need to machine the faces, 0.5mm on each side. That is because otherwise they will not fit on the crankshaft.
Then, you will need to machine 0.1-0.2mm from the outer sides of the connecting rod, where the bolts are. So that the rod can enter the combustion chamber. Otherwise they are wider than the diameter of the cylinder and cannot enter!
That's all ! I have installed these rods in my second engine using the modifications I described above.
Old Sep 17, 2012 | 07:52 PM
Raymazing's Avatar
Raymazing
I'm making about 290 whp (mustang dyno) on a stockot
Old Sep 17, 2012 | 07:55 PM
Raymazing's Avatar
Raymazing
Stock motor I'm sorry phone geeked I'm also running all aftermarket boost control. I would be a little more scared with the factory boost spikes in the mid range.
Old Sep 18, 2012 | 06:51 AM
SooperCuperErik's Avatar
SooperCuperErik
Aftermarket boost control... is this what i suggested to you?
Old Sep 18, 2012 | 07:05 AM
Raymazing's Avatar
Raymazing
Not following Eric.
Old Sep 18, 2012 | 07:19 AM
SooperCuperErik
You asked how I controlled my boost cuts via PM... due to the boost spikes
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
