Drivetrain Ballpark HP based on mods
Old Jun 30, 2011 | 05:17 AM
firenewt's Avatar
firenewt
I don't have easy access to a dyno so I don't know how much hp Fizzgig is making. Anybody have an idea based on the mods?
thanks in advance,
Kevin
Old Jun 30, 2011 | 09:36 AM
N2MINI's Avatar
N2MINI
Hard to say. Do you have a ECU Tune from anyone?? if not you need one in a bad way!!!
Without a tune I'd guess very low 200's
With Tune high 220's maybe more and could be quite a bit more depending on how the RMW cam works with that head..
Without the header, cam, and head but with a good tune you'd be right around 190's
Lot of varibles at play.. Never seen those brand mods together, but have seen more then a few with, pulley, cat-back, CAI, and RMW head, header, cam and tune and you'd be around 240's.. Got to plan mods like that together regardless of what brand your using..
Old Jun 30, 2011 | 09:46 AM
ZippyNH's Avatar
ZippyNH
I bet 210-220....
With no tune, the limit toyour hp is fuel....the 380's should max out 210hp or a bit more...and you are most likely a bit lean....so 220 seems right.....
Bigger injectors and a tune....you might get (with a strong motor) closer to 240+....andbe much safer motor wise with better drivability....
Old Jun 30, 2011 | 01:30 PM
firenewt's Avatar
firenewt
Originally Posted by ZippyNH
I bet 210-220....
I have 440's from Jan. Missed Jan in Louisville due to illness, but fully intend on getting the tune. Have a Dimsport so a remote tune is a possibility but would prefer a hands on Jan tune. Fizzgig is disabled at the moment with a clutch problem. Know whats wrong and have the parts to fix it. Unfortunately my health is in the toilet and the garage that installed the clutch says it not their problem - typical. Don't have the cash to have someone else do it. My dad died in Feburary and I had to cover the funeral costs. It's damn expensive to die.
Kevin
Old Jun 30, 2011 | 01:42 PM
firenewt's Avatar
firenewt
Wanted to go full-on RMW but it didn't work out. So, based on extensive discussions with vendors, I ended up with what I have. Beside, mix and match can be fun. Also, the Milltec and Magnaflow were the best available at the time - fall 2002.
Kevin
Old Jun 30, 2011 | 02:31 PM
cct1's Avatar
cct1
Kevin
Find a dyno that can datalog, and you can do a remote tune in real time.
minimofo
Sep 30, 2015 12:26 AM
dscott90000
Sep 9, 2015 07:55 AM
larryd96
11
Sep 8, 2015 05:01 AM
schwac2
Sep 3, 2015 08:56 PM
