Drivetrain Is Alta hose necessary for a Alta intake?
Old Jan 29, 2004 | 11:41 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I've heard conflicting opinions on this. Some say without bigger throttle body, the hose is useless; whereas other feels that in order to maximize its potential is with the hose. What do you think? :smile:
_________________
04 IB/W JCW MCS
Old Jan 30, 2004 | 05:40 AM
Super_MINI's Avatar
Super_MINI
I have the Alta w/hose. It's not necessary to have the hose and it probably doesn't add much in performance. I would buy it if you think it's worth the added engine dress up or if you plan to significantly do performance mods to the engine later on.
Old Jan 30, 2004 | 05:41 AM
Storer's Avatar
Storer
Waste of $ IMO
Old Jan 30, 2004 | 07:42 AM
apexer's Avatar
apexer
I have the Alta without the hose and you can feel the difference in power. The reason I did not get the hose is that Randy felt it made little difference unless you had the larger throttle body.
Old Jan 30, 2004 | 07:54 AM
Nobull60's Avatar
Nobull60
Maybe true but it sure does look cool.
Old Jan 30, 2004 | 09:34 AM
dcsmd007's Avatar
dcsmd007
>>... Randy felt it made little difference unless you had the larger throttle body.
That's the impression I have, but Randy also said that improved cylinder head will also benefit from the hose. How much more air does the hose provide? What's the difference in the diameter? :smile:
Old Jan 30, 2004 | 06:51 PM
fishey72's Avatar
fishey72
Looks cool, some people say that you may get less air turbulence with it's smooth interior walls thus leading to a fraction of performance. Which adds up to the surface of snake oil. IMO.
I got the hose, but I plan on a throttle body once the Yo-Yo issue is resolved or rephixed.
Old Jan 30, 2004 | 07:10 PM
ZAMIRZ's Avatar
ZAMIRZ
Pain in the *** to install b/c you gotta do some snipping here and there to make it fit. On top of that, the fitting for the breather is pointing in the wrong direction so you have to sort of shoe-horn it into place. Waste of money IMHO (and I have it).
Old Jan 30, 2004 | 07:17 PM
dominicminicoopers's Avatar
dominicminicoopers
It'll be just the thing to have once my TB goes big bore. It looks cool too.
patsum
26
May 29, 2021 06:29 PM
rtk90
Aug 29, 2019 09:08 AM
makg
Sep 10, 2015 11:59 AM
eliseo1981
Sep 4, 2015 02:33 PM
Hippiehobbit267
Sep 1, 2015 06:13 PM
