Drivetrain oil in #1 plug; others ok....need advice
Old Mar 31, 2011 | 04:23 AM
GPToyz's Avatar
GPToyz
So i'm swapping out my plugs for the JCW ngk plugs during my pulley install.
I pull the #1 plug and my plug is literally drenched with oil, the other 3 seem to be okay.
My searches online say that a valve cover gasket set replacement ought to cure things right up.
Is that the consensus?
Old Mar 31, 2011 | 06:52 AM
jhiggs26's Avatar
jhiggs26
You need # 5 to stop oil from invading spark plug tubes.
http://www.realoem.com/bmw/showparts...87&hg=11&fg=15
Jeremy
Old Mar 31, 2011 | 08:08 AM
GPToyz's Avatar
GPToyz
thanks jeremy!
Old Mar 31, 2011 | 08:38 AM
element's Avatar
element
i just got a set of rings + gasket and will install next weekend.
Old Mar 31, 2011 | 10:02 AM
GPToyz's Avatar
GPToyz
are you having the same problem?
Old Mar 31, 2011 | 12:22 PM
ggcadc's Avatar
ggcadc
an FYI, the spark plug seals were VERY hard for me to get off on my own, pliers, vice grips, nothing worked, had to take the valve cover to the dealer, they got them off and put the new ones on for free, it was a bad day , but in the end it was resolved, just a heads up...
the reason they were hard to get out is that they arent just rubber, they are rubber coated metal seals that seem to be pressed in.
sevin
May 2, 2026 06:11 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
tr3y003
Oct 22, 2015 10:48 AM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
