Drivetrain Anyone install a B&M shifter on an 04 build?
Old Jan 13, 2004 | 08:00 PM
d2mini's Avatar
d2mini
Sounds like there was a design change in the original shifter that prevents the Alta from being installed. What about B&M? My kit is sitting in my garage, i just haven't gotten around to doing the install yet... :???:
Old Jan 13, 2004 | 08:06 PM
sbgobig's Avatar
sbgobig
B&M shifter works in my 04.
Old Jan 13, 2004 | 08:08 PM
MiniPilo's Avatar
MiniPilo
BM is looking into this. I have contacted my BM distributor, and let them know about it. I will let you know what i find.
Dan
Pilo Racing
Old Jan 13, 2004 | 08:11 PM
d2mini's Avatar
d2mini
Thanks MiniPilo!
sbgobig, what was your build date? Mine was mid-november.
Old Jan 13, 2004 | 08:23 PM
cdconsor's Avatar
cdconsor
I've got the Promini in my Oct build 04. Promini is exactly the same thing as the BM, only difference is the fact that the cheapo aluminium shift **** says Promini on top instead of B&M.
Other than that it works great. Install was a little challenging because I was in constant fear of breaking one of the many plastic pieces but all in all well worth it. Slap a whalen on top and you are good ta go.
Chuck
Old Jan 14, 2004 | 05:32 AM
d2mini's Avatar
d2mini
The rumor is the Oct build 04's are the old design, and the new design wasn't implemented until nov or dec builds. Thanks for the info though! :smile:
Old Jan 16, 2004 | 05:08 AM
aokdoug's Avatar
aokdoug
got my b&m s-h about 2 months ago.
my s has a 12/2/03 build date.
ready to install now.
do i have a problem?
thanks doug
Old Jan 16, 2004 | 05:20 AM
MeanGRN's Avatar
MeanGRN
I'm in the same position as you doug, except my build date is a couple weeks later. I hope this doesn't cause problems. :evil:
Cheers,
JD
Old Jan 16, 2004 | 12:31 PM
d2mini's Avatar
d2mini
haha, looks like we all bought ours awhile ago but were all too busy to install!
So no one with a mid november and later build date has done this mod?
Old Jan 17, 2004 | 10:02 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I also bought the kit back in Oct. But I didn't get my car until Jan. (Dec built). So, I guess I'm in the same boat as you guys.
I have a feeling it will not fit.
_________________
04 IB/W JCW MCS
Old Jan 21, 2004 | 08:55 AM
d2mini's Avatar
d2mini
Well, i just got off the phone with B&M. The tech said the current shifter WILL NOT fit an 04 MINI.
And they are still looking for an 04 car to use to design the new one from the way it sounded. So if you are on the west coast you may want to give them a call.
http://www.bmracing.com/
Old Jan 24, 2004 | 05:27 AM
04CooperS's Avatar
04CooperS
I will second the comment above. I purchased a Pro Mini shifter before my car arrived (Nov 04 build and delivery). I had read somewhere that the change was made in the middle of November, so I was hoping it would still fit. I went down today and of course...nope. An easy way to check is to pop the trim ring inside and look at the "shifter" box. If it is black plastic, like mine, then then new shift lever won't fit. I ended up taking everything out to make sure. The label on the shifter box has a date. Mine is 10/29/03. Hope this helps.
04CooperS
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
nomar116
Aug 21, 2015 04:36 PM
jcb-memphis
Aug 8, 2015 11:09 AM
