Drivetrain jcw intake wiring
Old Mar 4, 2011 | 08:49 AM
12magnum's Avatar
12magnum
jcw intake wiring
just bought a used JCW intake for my 2005 MCS. i have installed it and i am currently just running it with the flapper valve open. the used intake came with no wiring harness. i need help figuring out how to wire it up! the factory instructions are useless. i see 1 wire goes to pin 8 on the fuse box, easy enough. 1 wire to pin 113 on ecu easy enough. 1 wire to ground, no problem. the problem is there are only 2 connections at the solenoid on the air box so were do i connect 3 wires?
Old Mar 4, 2011 | 08:56 AM
JPMM's Avatar
JPMM
Don't bother with the wiring ,its a pain , just remove the flap , vacuum canister , and all the other stuff. Then you don't have to hook up the vacuum line either , its a pain too.
Old Mar 4, 2011 | 09:49 AM
FranticFreddy's Avatar
FranticFreddy
Yea, what JPMM said. Don't bother with all the hookups. Remove the flapper and your good to go!
Old Mar 4, 2011 | 10:45 AM
quikmni's Avatar
quikmni
I removed the flap and all the guts on my JCW intake.
However, I do get a little bit of a whistle sometimes at lower RPMs and low load. The good side is that I hear the great intake noise better, all the time.
The flap is there to reduce noise at lower RPMs.
Old Mar 4, 2011 | 11:44 AM
Checkmate_2006's Avatar
Checkmate_2006
don't bother with the wiring. I was debating it when installing my JCW CAI, but definitely glad I decided to leave the flap open.
Old Mar 4, 2011 | 02:47 PM
Crashton's Avatar
Crashton
I figured since it had the wiring & the flapper I'd use them. My needs may be different than others. For me a quiet intake that is only loud when I'm hammering on it was why I bought the JCW. If one wants noise there are cheaper alternatives. The supplied directions worked for me.
Magnum if you want PM me your e mail addy & I'll send you a PDF of the instructions I used.
Old Mar 4, 2011 | 03:27 PM
Checkmate_2006
here are the install instructions:
http://motoringfile.com/files/JCWUPGRADE.pdf
Old Mar 4, 2011 | 04:24 PM
JPMM's Avatar
JPMM
The difference in sound is not that much to go through the trouble of hooking up the flap . It's just one more thing to go wrong. I went through the whole ECU brain surgery wiring thing then removed everything a year later
Old Mar 4, 2011 | 07:04 PM
Crashton's Avatar
Crashton
Well whatever floats your boat.
I like stuff to work, but i'm funny that way. Maybe I got lucky my install was easy.
Old Mar 4, 2011 | 07:39 PM
Checkmate_2006
My install was very easy. I just chose to leave out the wiring and open the flap. My intake works just fine and sounds great.
Old Mar 5, 2011 | 06:18 AM
Crashton's Avatar
Crashton
Different strokes as they say. What sounds great to one person may sound like an obnoxious noise to another.
Motor on....
Old Mar 5, 2011 | 12:01 PM
howsoonisnow1985's Avatar
howsoonisnow1985
I took the time to remove mine...open all the time 24/7!
They call it the John Cooper Motorsport (JCM) mod because then JCM in Sussex, England would prepare the Challenge race series cars without the flap removed. They actually sold these JCM "modified" JCW CAI.
Old Mar 8, 2011 | 07:35 PM
louisut's Avatar
louisut
First, do you have all the wires? There should be three: red, yellow and black.
Old Mar 9, 2011 | 07:23 AM
12magnum's Avatar
12magnum
Now that people are done hijacking my thread and having a flap vs no flap arguement, I'll chime in again. I have no wiring harness! That's my problem. The factory instructions assume you have the harness so they do me no good. If nobody can help me make a harness, can i buy one from mini dealer parts department? I saw no seperate part number for the harness.
Old Mar 9, 2011 | 09:37 AM
Professor's Avatar
Professor
No flap . Sorry man I had to.
I will do some looking around for a number
Old Mar 9, 2011 | 09:40 AM
Professor's Avatar
Professor
Sorry man I cant find anything in our parts database.
Old Mar 9, 2011 | 05:23 PM
12magnum's Avatar
12magnum
maybe somebody here that was too cool to use the factory wiring and is running with their flap open would want to sell their harness
Old Mar 9, 2011 | 05:24 PM
Professor's Avatar
Professor
I dont think mine came with one either sadly. But maybe someone will chime in with one.
Old Mar 9, 2011 | 05:45 PM
JCW03's Avatar
JCW03
I installed mine 2 weeks ago, I gutted it as well, full air full time !!
I will have a look but I am pretty sure I still have the wiring with module all in tact.
Old Mar 9, 2011 | 06:37 PM
4wheels's Avatar
4wheels
If nobody else can find one for you, PM me and I'll look for mine. The noise increase was relatively low so I removed all the guts & have everything stored away somewhere... just have to find it if you want it.
Old Jan 9, 2012 | 02:13 AM
Willy_sa's Avatar
Willy_sa
Hey
I just got my JCW intake from a friend with the wiring harness. Althou I will use it and i understand why you would want to. Think it is easy to make up the wiring harness. If you want i can make you a drawing of the harness. Then you can just use the normal instructions. But now her is my question. Will it work on a standard S just by hooking up the wires? Or do you need to do the JCW ECU flash?
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
The_Kid
Aug 28, 2015 04:50 AM
massmini03
Aug 12, 2015 11:19 AM
