Drivetrain Gasket
Old Feb 27, 2011 | 04:21 PM
FlynHawaiian's Avatar
FlynHawaiian
Gasket
I picked up a used Milltek Catback for my '06 MCS, and am wondering if I should get a new gasket for between the oem manifold and the piece that connects to it. Also, what about the connection between the resonator and the muffler connection.
If so where should I get the gasket from. I've used fel-pro in the past for my mustang, but I’m not to sure on what the mini would use.
Old Feb 27, 2011 | 06:42 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
New gaskets are a good idea, as well as clamps. I got all OEM from dealer. May need new flange nuts/bolts too depending on how easy your old system comes apart.
Old Feb 27, 2011 | 09:03 PM
FlynHawaiian
So you think the oem gaskets are the way to go? I figured the opening from the manifold to the resonator might be bigger.
Old Mar 1, 2011 | 04:56 PM
stewpify's Avatar
stewpify
when I put the B&B exhaust on the OEM gasket after the cat was too small for the opening. It fit the bolt holes, however the inner part of the gasket protruded into the exhaust path.
vulkandino
Oct 31, 2015 08:29 PM
vetsvette
Oct 11, 2015 06:05 PM
silence2-38554
Sep 28, 2015 12:19 PM
Nicefeet
Sep 27, 2015 11:14 AM
Nicefeet
Sep 24, 2015 06:53 PM
