Drivetrain M7 16% reduction pulley
Old Jan 24, 2011 | 04:56 PM
  #26
MINI33342's Avatar
MINI33342
Originally Posted by checkmate2006
No
+1
Old Jan 27, 2011 | 04:40 PM
  #27
26trackt's Avatar
26trackt
Need a 15% charger pulley
Can any body recomend a quality 15% charger pulley that can be shipped the same day it's ordered?
My head is about to explode. We decided to get a 15% . Thought it would be a safe small change that would provide better "seat of the pants" performance & braggin' rights. Did a little (very little) poking around & ordered one from Alta. Can't get one shipped in a reasonable time frame. Car was torn down for a coolant leak & is waiting for a pulley to go back together. We didn't mind waiting a little over a week for the back order but we keep getting reports that the back order is getting longer & longer. We have spent a week ordering & cancelling orders that can't be filled. Come to mention it we haven't seen that matching belt yet either. I can't say I'm mad at Alta but I need a freakin' pulley.
Old Jan 27, 2011 | 04:48 PM
  #28
MINI33342's Avatar
MINI33342
Contact Way at waymotorworks.com
He'll take care of ya.
Old Jan 27, 2011 | 05:37 PM
  #29
minigofast's Avatar
minigofast
ok, so im going to get a 17% kit from way, but I also plan on getting either the 2% or 3% crank pulley from alta/ cravenspeed. From what I have been hearing these two pullies add together and would give me the equivelant of a 20- 21 % reduction correct? If so thats, no bueno without an intercooler and meth. Anyone have a similar setup or am I wrong on my thinking? any help?...Way?
Old Jan 27, 2011 | 08:57 PM
  #30
davisflyer's Avatar
davisflyer
I'd be weary of installing one of the above mentioned crank pulleys as they do not have harmonic balncers on them and have the potential of messing up your engine. Since you are going to order the 17% kit from WMW, why not go for the ATI Super Crank Pulley http://www.waymotorworks.com/super-d...ulley-r53.html ? You can get it 2% oversized as well!
Old Jan 28, 2011 | 03:49 AM
  #31
daflake's Avatar
daflake
+1 for what davisflyer said. If you are going to do a crank pulley either ATI or stock.
Old Jan 28, 2011 | 05:01 AM
  #32
mgrant's Avatar
mgrant
I thought you did need to have a dampened crank pulley unless you are always near/at redline. I would recommend te alta lightened (not oversize) crank pulley.
If you r going the oversize route do get a dampened pulley since with 21% reduction those dangerous frequency normally not reached will b in sight
Old Jan 28, 2011 | 05:50 AM
  #33
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We have pullies in stock and can ship today, or even overnight if you need.
BAD IDEA, 20-21% reduction would be waaaay to much. You would over spin the supercharger and water pump, and also throw over boost codes.
If you want a crank pulley you should go with the ATI damper. I do not recommend the aluminum lightweight crank pullies. Without the damper it is hard on the bearings, and oil pumps. Oh and yes there is proof of this. The last two motors I did had lightweight crank pullies and you should see the bearings out of them, they are in horrible shape.
Old Jan 29, 2011 | 07:50 AM
  #34
Rycase's Avatar
Rycase
Do you offer a pulley puller rental with order?
Old Jan 29, 2011 | 07:10 PM
  #35
WayMotorWorks
Vendor
Yes when you buy one of our WMW pullies we rent it to you for FREE
Old Feb 6, 2011 | 08:39 PM
  #36
mgrant's Avatar
mgrant
do you need a small size belt if you are going 16% ???
Old Feb 9, 2011 | 11:52 AM
  #37
Checkmate_2006's Avatar
Checkmate_2006
I have been on the fence over a 15% or 17%. I read that 17% could shorten the life of the engine. I really don't want that.
Old Feb 9, 2011 | 01:08 PM
  #38
Agarwaen's Avatar
Agarwaen
I don't really think 17% will cause any more problems than you will have with a 15% or even stock(other than belt wear, 17% belts should be changed every year or so). Really if an engine/SC is going to go, it will go with or without pulley mods. I just saw a thread the other day where Steve at SRTech said he has been running 18% reduction for something like 152,000 miles with no problems other than a leaky thermostat, and a bad bpv.
Old Feb 9, 2011 | 04:06 PM
  #39
mgrant's Avatar
mgrant
to you rent only if we buy the WMW pullies or any pulley u sell ?
Old Feb 9, 2011 | 04:18 PM
  #40
WayMotorWorks
Vendor
ONLY if you buy a pulley from US, I don't care which of our pullies you buy, but I try to make recommendations.
Old Feb 9, 2011 | 07:59 PM
  #41
Checkmate_2006
sounds fair.
Old Feb 10, 2011 | 01:30 PM
  #42
mgrant's Avatar
mgrant
Way ... ill definetly give you a call when i buy the pulley (in around 1month) and a couple of other things to make the mini a bit faster
Thanks for all the help
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
WhinyR53
Sep 30, 2015 07:36 AM
daviday
Sep 25, 2015 01:31 AM
