Drivetrain Who here installed the Way pulley
Old Dec 31, 2010 | 01:46 AM
Chrisr53mini's Avatar
Chrisr53mini
In the instructions it says to back it off .020 to .025 but the guy I talked to said no.........to bottom it out all the way??
Old Dec 31, 2010 | 06:35 AM
Agarwaen's Avatar
Agarwaen
Bottom it off, then back it out a miniscule amount. Otherwise, your pulley is going to be rubbing on the SC. No idea how that could ever be a good thing.
Way's instructions are good, Way knows what hes talking about.
Old Jan 6, 2011 | 06:25 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I just put the center part on all the way, don't force it down, then put the outer part on. Then the screws will pull the center part away from the metal ring on the snout seal. If you want to pull it off the seal .20 that won't hurt. I've just done it so many times I don't have to think about it. The most important thing is that the shaft bottoms out in the back of the pulley.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
