Drivetrain question about programming ECU?
Old Dec 17, 2010 | 03:23 PM
Krilbj's Avatar
Krilbj
Im trying to get a borla type-s exhaust for my 10'MCS
what I want to know is if i ONLY change the exhaust on it without any programming
would it cause any problems? like messing up the oxygen sensor or getting a check engine light on??
Thanks in advance! I need advices... oh bytheway my mini is leased.
Old Dec 17, 2010 | 03:40 PM
Smigetsmall's Avatar
Smigetsmall
If it's a cat-back, then there won't be any problems.
If its a full system:
cat-less, definity have chech engine light.
with cat, might have a check engine light if the cat doesn't provide an adequate reaction with the exhaust gases.
Old Dec 17, 2010 | 04:19 PM
Krilbj's Avatar
Krilbj
Thank you for your advice
I believe this is the system that I'm trying to buy
would I have any problems?
http://www.borla.com/products/produc...rod_sku=140261
Old Dec 17, 2010 | 09:49 PM
MCSfanboy's Avatar
MCSfanboy
I'm running the equivalent Borla exhaust of my neo classic R53 with zero problems. If it's a cat-back, you're good to go!
Old Dec 18, 2010 | 05:10 AM
richardsperry's Avatar
richardsperry
I installed an Invidia Q300 a couple of weeks ago. It replaces everything from the downpipe V band clamp to the muffler. (resonator and second cat). No check engine light, nothing...
Sounded great to me but wife of 25+ years said it had to go... (she thinks I'm like a 9 year old with a drivers license...lol) So it's easier to put the stock exhaust back on, than swap the wife out for a newer model... A lot less expensive too.
Old Dec 21, 2010 | 04:26 PM
automan21's Avatar
automan21
I think its a bit pricey for just a catback that looks like that. Id go for something in the $500-$700 range. Cat backs are usually safe. Did a few on other cars and no problems so far.
Old Dec 21, 2010 | 07:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You won't have any check engine light problems with just a catback exhaust. I would warn that with the borla you have to remove the center cross support, so I don't recommend it. Also just a catback exhaust won't gain any HP on a turbo MINI.
Getrieben
Sep 21, 2023 03:31 PM
TREX
Nov 2, 2019 07:31 PM
DeniseNY R52
May 17, 2016 05:16 AM
robbiedowns22
Aug 25, 2015 12:20 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
