Drivetrain OCC needed on 2011 MCS?
Old Aug 30, 2012 | 10:22 PM
  #276
Mini'mon's Avatar
Mini'mon
Intake Valve Inspection, N18 Engine 8/29/12
So Charlie Victor stopped by the shop yesterday and we pulled his intake manifold to take a look-see. If you know which bolts and nuts to remove, it takes about 20 minutes to pull the factory airbox and manifold.
A little background about the car:
This well maintained 2011 R55 MCS has 12,505 mostly highway miles and it doesn't get thrashed around at the track and twisties (= not spending alot of time in stop and go traffic or elevated RPMs). It's had 3 oil changes over its lifetime and always gets 91 octane Chevron and Shell fuel. Also, keep in mind that it's a SoCal car that does not see extreme temperature variance as the seasons change (= not alot of water vapor exposure in the PCV system because it's never seen a day below ~=37 degrees F or so.)
Here are some pics of the intake valves:
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Yes, even on this kindly kept MCS we have carbon buildup! Maybe a tad less than on the N14, but it's there. It's forming a porous black surface on the outside of the valves. This will likely become an uglier situation as seals, gaskets, & rings age and more vapors are introduced into the PCV system.
Do you see the PCV ports built into each intake port on the N18? It's like the spent oil vapor and blowby byproducts have an even more direct path to the valves than on the N14. The Cylinder 2 port even has some oil dripping out of it.
I installed a prototype, lower priced, N18 Oil Catch Can (OCC) that we were working-on in conjunction with BSH on Charlie Victor's car. (It was an on-again, off-again effort that was shelved for a while because we did not know if the N18 would even need this preventative maintenance item.) It's a completely reversible, easy to install mod that will greatly minimize the amount of harmful PCV system vapors available to cake on the valves.
Based on yesterday's discovery, I placed an order for more OCC's from BSH today. (BSH is doing the oil catch cans. DoS is doing the fittings that attach to the turbo inlet hose and valve cover.) We will have our new, house brand, N18 OCC kit on sale at defendersofspeed.com by early October 2012. It will retail for $215.00, but we'll be offering pre-order pricing of $200.00 (+ shipping). We will have a pre-order link up on the site next week. If you can't wait until then, drop me an email and I'll shoot you a PayPal invoice.
-Clint
P.S. DoS will have a Seafoam fogger available for the N18 coming soon as well. Should be able to have these ready by November. We got some great ideas yesterday!
Old Aug 31, 2012 | 03:35 AM
  #277
bmwr606's Avatar
bmwr606
what did you do to Charlie Victor's intake tracks/valves while the intakes were exposed? seafoam? walnut shell blasting?
are there "after" photos?
scott
Old Aug 31, 2012 | 04:00 AM
  #278
Hyland33's Avatar
Hyland33
I'll definitely be picking one up. Still only have 2100miles on the car so I might as well get it on asap
Old Aug 31, 2012 | 08:03 AM
  #279
NewCooperFanatic's Avatar
NewCooperFanatic
Well I'm sure glad I've already purchased/fitted one for my 2012.
Thought I bought something that was unneseccary...glad its not
Old Aug 31, 2012 | 09:16 AM
  #280
Mini'mon's Avatar
Mini'mon
scott
Hi Scott,
We did not have time to do a cleaning that day. It didn't make sense to do so until some more carbon accumulates because it's a messy and slightly time consuming process. However, once you get the intake manifold off, it's easy to do a Seafoam soaking + scrub, Gun Cleaner soaking + scrub, or Walnut shell blast.
-Clint
Old Aug 31, 2012 | 12:02 PM
  #281
automan21's Avatar
automan21
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
-Clint
From that first pic It seems that with the occ set up a strut tower brace will not fit.
Old Aug 31, 2012 | 12:11 PM
  #282
squawSkiBum's Avatar
squawSkiBum
Moderator
Clint,
thanks for the pictures on this. Two questions:
1) with the direct pvc ports to the intakes (already discussed to death in another thread) it seems that an OCC will help but won't be anywhere near as effective as on the N14 engine. Any thoughts?
2) will you offer the fittings as a separate kit from the BSH OCC for those who want a different OCC?
Old Aug 31, 2012 | 12:35 PM
  #283
cesar418's Avatar
cesar418
Wow i got 30k on my n18, no wonder i feel the car a little weird and rough idling!
Old Aug 31, 2012 | 04:44 PM
  #284
jomama's Avatar
jomama
am i the only one who doesn't think that looks too terrible? i mean, seriously, at the temps that the engines run, there's no way in hell you can keep the top side of the valves from turning black. granted, CV's car only has 12k miles on it, and more miles will result in more "build up", but this looks nothing like some of those valves i've seen on some n14s. plus, if you can't plug the route from the crank back to the intake manifold, adding an occ will only get you half way there. sure, it's better than none of the way there.
i know this is impossible, but i wish i could bring my car up there for a look-see. i have 25k on my car, and live in socal, so i drive in the same climate as CV. the first 10-12k miles were city miles, and the other half have been mostly highway, since me moved out of LA and into OC. i guess time will tell how bad this problem really is.
Old Aug 31, 2012 | 04:49 PM
  #285
jomama's Avatar
jomama
check out the pics in this thread about carbon buildup. for some reason, i don't think CV's will get to that level with 3-4x's as much driving. just my guess tho.
https://www.northamericanmotoring.co...on-issues.html
Old Aug 31, 2012 | 05:01 PM
  #286
Mini'mon's Avatar
Mini'mon
Nah, it's the same location as the N14 OCC. Folks run strut tower braces all the time. If you want ~=1/2" more clearance, just mount the OCC under the alarm tab instead of on top of it.
Originally Posted by squawSkiBum
Clint,
That's a really difficult question to answer without more testing. In full disclosure, no OCC will ever get all the harmful spent oil, water vapor, and blowby mix out of the engine. The goal of a good OCC is significant reduction.
I've pulled the PCV line from the turbo inlet hose on nine N18 equipped MINIs now and they're all super oily (not light vapor residue, but dripping oil) three of them were Coupes, Roadsters, and Countrymans that came off -the lot a couple of weeks ago. This indicates one outlet for that nasty PCV system mix. An oil catch can contains this source contamination and will reduce the byproducts that can escape from the PCV ports in the cylinder head.
I want to see if DoS can find a simple way to plug the PCV ports in the head -or- design a filter for the PCV system in the valve cover. Anyone in SF want to drop their MINI at the shop for a few days?
Maybe in the future, but no direct plans to do this.
Yup, maybe . . .
Old Aug 31, 2012 | 05:14 PM
  #287
Mini'mon's Avatar
Mini'mon
I agree, Charlie Victor is not the worst case scenario for carbon buildup. His maintenance habits and care to not beat on the engine alone will probably not allow quite this level of buildup to happen at 40K.
However, carbon builds in layers. The foundation is definitely there and that vapor loves to stick to rough surfaces like castings that are not constantly bathed in a solvent like gasoline or water-meth.
I also agree that time will tell. . .
-Clint
Old Sep 1, 2012 | 06:50 PM
  #288
DneprDave's Avatar
DneprDave
Could a head cover gasket be made with the holes to the intake port blocked off?
That would have the same effect as blocking off the PCV hose on an N14 engine.
Dave
Old Sep 1, 2012 | 07:03 PM
  #289
Mini'mon's Avatar
Mini'mon
Dave
Interesting idea, maybe a valve cover gasket could be made. Maybe it's even simpler than that. Sounds like it's time to start playing.
Just got to pull a valve cover and dig a little deeper into that cylinder head to see what's the best fit.
Old Sep 1, 2012 | 09:00 PM
  #290
Bullie's Avatar
Bullie
You know Clint, I was toying with an idea last week to help out with the oil buildup problem. I think, when used in conjunction with a catchcan, it might prove highly effective. It is really quite simple, but often overlooked. Not sure of the implications of it, but you may be able to chime in on it. How about using the Seafoam in the oil, like it says you can do? They say it prevents sludge buildup, etc. Wouldn't it help in this instance as well? Thanks in advance for your insight.
Old Sep 2, 2012 | 01:32 AM
  #291
Mini'mon's Avatar
Mini'mon
You benefit from adding Seafoam to your oil if you have a car that's suffering from deferred regular maintenance or you're getting sludge inside your engine & its moving components. Even though they do burn some oil as seals, gaskets, and piston rings age, this never been an issue on MINIs that get regular oil changes (at 4K to 7K mile intervals with synthetic oil).
Carbon buildup is a different issue than engine sludge, so DoS does not recommend adding it to your oil.
-Clint
Old Sep 2, 2012 | 10:25 AM
  #292
Bullie's Avatar
Bullie
-Clint
Yes, I do understand that the carbon build up issue is different than sludge in the oil. My thinking was, that maybe the same compounds that prevent the buildup of sludge, would also prevent the buildup of carbon from the oil vapors, as well.
Thanks for taking the time to reply Clint!
Old Sep 11, 2012 | 10:28 AM
  #293
MINI_Turbo_1966's Avatar
MINI_Turbo_1966
I have the boost tap currently installed in full-block mode and am possibly doing a reconsider. I am prob going to install a second OCC since I have several already and then observe what the effect (or lack of effect) really is, since I am beginning to suspect that excessive sump pressure is being generated. The N14 had two pipes for a reason and think I'm possibly seeing some valve cover gasket outgassing because of it, If I go this route I will try to post observations.
Old Sep 11, 2012 | 10:53 AM
  #294
Mini'mon's Avatar
Mini'mon
With or w/o a Boost Tap, the N14's valve cover gasket is prone to leaking. The material that BMW/Peugeot selected for the gaskets is not as heat and chemical resistant as it should be.
There are quite a few threads discussing this valve cover gasket leaking and dual oil catch cans on NAM and other forums. You should probably re-post on a thread discussing the N14 engine. This thread pertains to the newer N18 engine found on the 2011+ MCS.
Old Sep 15, 2012 | 03:27 PM
  #295
masternut's Avatar
masternut
What would happen if you just ran the PCV hose to the atmosphere?
Old Sep 15, 2012 | 08:17 PM
  #296
Bullie's Avatar
Bullie
It would make a mess, depending on how you routed it, and the EPA will kill a kitten for every day that you ran it that way.
Old Sep 15, 2012 | 10:39 PM
  #297
DneprDave's Avatar
DneprDave
That's the way they did it before '68. They ran a pipe under the car and called it a draft tube. The air running past the end of the tube drew the crankcase vapors out.
Dave
Old Sep 16, 2012 | 04:49 AM
  #298
k_h_d's Avatar
k_h_d
My 2012 JCW has an N14 engine right? I have 2400 miles. Do you feel that putting an OCC on my car would eliminate any buildup in the future? I thought I read Way sat that our turbo cars do not benefit from the catch cans like the supercharged did.
Old Sep 16, 2012 | 05:19 PM
  #299
mbwicz's Avatar
mbwicz
There are several threads here that discuss this topic. If I just spent the money on a new JCW, $200 for a catch can seems like a good insurance plan. IMO, I can't see the down side, except for the $$$.
Mike
Old Sep 16, 2012 | 05:51 PM
  #300
RobMuntean's Avatar
RobMuntean
I think it would benefit for sure to purchase a OCC. There's no negative to having it. I'm at 37K on my MCS and I'm about to check for Carbon buildup and clean it all off if the valves are covered. I will purchase the OCC for sure after that point.
